Full Version: Python update for Addon
Hi
Can anyone help me updating this small addon made in python 2.1 to 3.0 to use it in Kodi 19?.
The addon is not mine. It was developed by Amet in Github https://github.com/amet/script.stop
I tried to contact the developer with no success.
The purpose of this addon is to stop paused video after set amount of time.
Thank you!!
This is the code of default.py
python:
# -*- coding: utf-8 -*-
import os
import sys
import xbmc
import xbmcaddon,xbmcvfs
import urllib,xbmcplugin
__addon__      = xbmcaddon.Addon()
__author__     = __addon__.getAddonInfo('author')
__scriptid__   = __addon__.getAddonInfo('id')
__scriptname__ = __addon__.getAddonInfo('name')
__cwd__        = __addon__.getAddonInfo('path')
__version__    = __addon__.getAddonInfo('version')
__language__   = __addon__.getLocalizedString
__cwd__        = xbmc.translatePath( __addon__.getAddonInfo('path') ).decode("utf-8")
__profile__    = xbmc.translatePath( __addon__.getAddonInfo('profile') ).decode("utf-8")
__resource__   = os.path.join( __cwd__, u'resources', u'lib' )
class MyPlayer( xbmc.Player ):
  def __init__( self, *args, **kwargs ):
    xbmc.Player.__init__( self )
    xbmc.log('MyPlayer - init')
    self.paused = False
  def onPlayBackStopped( self ):
    self.paused = False
  def onPlayBackEnded( self ):
    self.paused = False
  def onPlayBackStarted( self ):
    self.paused = False
  def onPlayBackPaused( self ):
    self.paused = True
  def onPlayBackResumed( self ):
    self.paused = False
player_monitor = MyPlayer()
counter = 0
delay = int(__addon__.getSetting("delay"))
while not xbmc.abortRequested:
  if player_monitor.paused == True:
    counter += 1
    if counter > delay*300:
      xbmc.Player().stop()
      counter = 0
  else:
    counter = 0
  xbmc.sleep(200)
Remember to change addon.xml to depend on python3
python:
import os
import xbmc
import xbmcaddon
import xbmcvfs
__cwd__        = xbmcvfs.translatePath( __addon__.getAddonInfo('path') )
__profile__    = xbmcvfs.translatePath( __addon__.getAddonInfo('profile') )
__resource__   = os.path.join( __cwd__, 'resources', 'lib' )
    self.paused = False
    self.paused = False
    self.paused = False
    self.paused = False
    self.paused = True
    self.paused = False
counter = 0
delay = int(__addon__.getSetting("delay") or 60)
monitor = xbmc.Monitor()
while not monitor.abortRequested():
    counter += 1
      player_monitor.stop()
      counter = 0
  else:
    counter = 0
  xbmc.sleep(200)
Thread moved to Python3 migration section.
(2021-05-19, 08:29)matthuisman Wrote: [ -> ]Remember to change addon.xml to depend on python3
python:
import os
import xbmc
import xbmcaddon
import xbmcvfs
    self.paused = False
    self.paused = False
    self.paused = False
    self.paused = False
    self.paused = True
    self.paused = False
counter = 0
    counter += 1
      counter = 0
  else:
    counter = 0
  xbmc.sleep(200)
Thank you matthuisman!!!
The addon worked like a charm
Thread marked solved.
Thanks for posting this thread.  The stopping of a paused playback, after a specific amount of time,  function is something I had never thought of.  I've now added this functionality to my uPNP server addon.  It's a great feature.
Jeff
