Full Version: Kodi 19.1 Crash at startup
Hello,
Kodi on the loading screen, I don't see something wird in the log (no errors):  https://paste.kodi.tv/ogiwuvuqon.kodi
I don't no if it's possible to deactivate the library update at startup without accessing the GUI ?
Thanks in advance for you help.
(2021-05-19, 23:15)Badguy Wrote: [ -> ]Hello,
Fixed by deleting guisettings.xml. => Solved
I always toggle the library update at startup, one bad archive/file and your stuck. It's just too easy to manually innate scanning when I want, instead of have that task take cpu slices in the background while I'm trying to watch a 4K at the limit of my hardware.
Thread marked solved.
