2021-05-20, 06:00
I was building Kodi in my Ubuntu desktop according to the guide given: https://github.com/xbmc/xbmc/blob/master....Ubuntu.md
It was fine till I ran command ` ` ` ./kodi-x11 ` ` ` to test Kodi in my ` ` `~/kodi-build` ` ` directory.
it shows ` ` `bash: ./kodi-x11: No such file or directory` ` ` .
Then for searching the reason for this anamoly I ran again the command to Configure build for X11.
It was the output:
~/kodi-build$ cmake ../kodi -DCMAKE_INSTALL_PREFIX=/usr/local -DCORE_PLATFORM_NAME=x11 -DAPP_RENDER_SYSTEM=gl
-- Source directory: /home/shardul/kodi
-- Build directory: /home/shardul/kodi-build
-- Generator: Single-configuration: Release (Unix Makefiles)
-- CMake Version: 3.16.3
-- System type: Linux
-- Linker: GNU gold
-- include/linux/dma-heap.h not found
-- Core system type: linux
-- Platform: x11
-- CPU: x86_64, ARCH: x86_64-linux
-- Cross-Compiling: FALSE
-- Execute build artefacts on host: TRUE
-- Depends based build:
-- statx is available
-- Checking to see if CXX compiler accepts flag -msse
-- Checking to see if CXX compiler accepts flag -msse - yes
-- Checking to see if CXX compiler accepts flag -msse2
-- Checking to see if CXX compiler accepts flag -msse2 - yes
-- Checking to see if CXX compiler accepts flag -msse3
-- Checking to see if CXX compiler accepts flag -msse3 - yes
-- Checking to see if CXX compiler accepts flag -mssse3
-- Checking to see if CXX compiler accepts flag -mssse3 - yes
-- Checking to see if CXX compiler accepts flag -msse4.1
-- Checking to see if CXX compiler accepts flag -msse4.1 - yes
-- Checking to see if CXX compiler accepts flag -msse4.2
-- Checking to see if CXX compiler accepts flag -msse4.2 - yes
-- Checking to see if CXX compiler accepts flag -mavx
-- Checking to see if CXX compiler accepts flag -mavx - yes
-- Checking to see if CXX compiler accepts flag -mavx2
-- Checking to see if CXX compiler accepts flag -mavx2 - yes
-- Could NOT find CAP (missing: CAP_LIBRARY CAP_INCLUDE_DIR)
-- Could NOT find ClangFormat (missing: CLANG_FORMAT_EXECUTABLE)
-- Could NOT find Dav1d (missing: DAV1D_LIBRARY DAV1D_INCLUDE_DIR)
-- Could NOT find MDNS (missing: MDNS_LIBRARY MDNS_INCLUDE_DIR)
-- Could NOT find Pipewire (missing: PIPEWIRE_LIBRARY PIPEWIRE_INCLUDE_DIR SPA_INCLUDE_DIR)
-- Could NOT find Sndio (missing: SNDIO_LIBRARY SNDIO_INCLUDE_DIR)
-- Found VAAPI: /usr/lib/x86_64-linux-gnu/libva.so (found suitable version "1.7.0", minimum required is "0.39.0")
-- FFmpeg 4.4 not found, falling back to internal build
-- dav1d not found, internal ffmpeg build will be missing AV1 support!
-- Could NOT find MariaDBClient (missing: MARIADBCLIENT_LIBRARY MARIADBCLIENT_INCLUDE_DIR)
-- Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
-- #---- CONFIGURATION ----#
-- Platforms: x11
-- -- PATH config --
-- Prefix: /usr/local
-- Libdir: /usr/local/lib
-- Bindir: /usr/local/bin
-- Includedir: /usr/local/include
-- Datarootdir: /usr/local/share
-- Datadir: /usr/local/share
-- Docdir: /usr/local/share/doc/kodi
-- ALSA enabled: Yes
-- AVAHI enabled: Yes
-- BLUETOOTH enabled: Yes
-- BLURAY enabled: Yes
-- CAP enabled: No
-- CCACHE enabled: Yes
-- CEC enabled: Yes
-- CLANGFORMAT enabled: No
-- CLANGTIDY enabled: No
-- CPPCHECK enabled: No
-- DAV1D enabled: No
-- DBUS enabled: Yes
-- INCLUDEWHATYOUUSE enabled: No
-- ISO9660PP enabled: Yes
-- LCMS2 enabled: Yes
-- LIRCCLIENT enabled: Yes
-- MDNS enabled: No
-- MICROHTTPD enabled: Yes
-- NFS enabled: Yes
-- PIPEWIRE enabled: No
-- PLIST enabled: Yes
-- PULSEAUDIO enabled: Yes
-- PYTHON enabled: Yes
-- SMBCLIENT enabled: Yes
-- SNDIO enabled: No
-- UDEV enabled: Yes
-- UDFREAD enabled: Yes
-- XSLT enabled: Yes
-- VAAPI enabled: Yes
-- GLX enabled: Yes
-- VDPAU enabled: No
-- MARIADBCLIENT enabled: No
-- MYSQLCLIENT enabled: Yes
-- Configuring done
-- Generating done
-- Build files have been written to: /home/shardul/kodi-build
Some packages are missing but I think configuration is complete. So can anyone please help why ` ` `./kodi-x11` ` ` is not running kodi.
It was the output:
-- Linker: GNU gold
-- Platform: x11
-- Platforms: x11
-- CAP enabled: No
-- CEC enabled: Yes
-- MDNS enabled: No
-- NFS enabled: Yes
-- GLX enabled: Yes
-- Configuring done
-- Generating done
