2021-05-24, 02:31
Hi all! Discovered an interesting little bug today when trying to playback flash (flv) video
When I set "Allow using DRM PRIME decoder" on, but disable hw accel with DRM PRIME, then playback of basically any media file gets a "std::bad_alloc" and a crash.
With both on, 4K plays well but flash (flv) files don't play - it tries for awhile and then also crashes with the same error.
With both off, flash (flv) files play perfect, but then all the HD files won't play at all (corrupted video and lag)
This behavior was not an issue on Leia.
I expect related to this:
https://github.com/xbmc/xbmc/pull/17724/files
FLV playback logs this:
2021-05-23 20:26:07.258 T:11246 ERROR <general>: ffmpeg[0x2a22c00X]: [vp6f] get_buffer() failed
2021-05-23 20:26:07.258 T:11246 ERROR <general>: ffmpeg[0x2a22c00X]: [IMGUTILS] Picture size 0x0 is invalid
2021-05-23 20:26:07.258 T:11246 ERROR <general>: CDVDVideoCodecDRMPRIME::AddData - send packet failed: Operation not permitted (-1)
I've confirmed FLV plays fine in ffmpeg, and obviously Kodi CAN play it with drm prime disabled, but the nothing else will play.
I posted this on discord but seems kinda quiet in there.
