Hello,
in the Skin Settings are few Addons which i can't find for LE Matrix
- Extendetinfo script,
- Weatherbit IO und
- User Rating
- Cinemavision
- Special Feautures
- Artwork Beef (wobei das gibts doch garnicht mehr oder)
- Library Editor Script
- My Picture Database
- Youtube Browser
- skin helper service
Where can i find this
Thank you
Those addons are probably not compatible with Matrix, so won't be available. ExtendedInfo Script is now obsolete, whilst the others have probably not been updated.
Hello, thanks for your answer, ok, then i have to wait. It is not good for the skin that these addons should be used as it says on the settings page
(2021-05-26, 19:27)Coolzero Wrote: [ -> ]Hello,
in the Skin Settings are few Addons which i can't find for LE Matrix- Extendetinfo script,
- Weatherbit IO und
- User Rating
- Cinemavision
- Special Feautures
- Youtube Browser
Thank you
All addons should be updated for Python 3.
If they won't be updated, they will eventually be removed from the skin.
A lot of addons are still in the process of getting updated.
- Extended Info, Skin Helper Service and My pictures Database have working versions in the forum threads
- Weatherbit IO has been removed from the supported addons section from the next skin version. Use Weather Multi instead.
- Library Editor has a working version in my development repo
- Artwork Beef is no longer needed as all features are built into Kodi and the scrapers now.
Always read the official forum skin thread when updating Kodi.
There's a reason I write and explain all changes in detail.
https://forum.kodi.tv/showthread.php?tid=343552
Hello,
thank you for your answer.
I have to search for the Matrix Addon's but i don't finde this:
- Skin Helper Service, when i tryed to install it from your Repo, i become a error message that it were not compatible. in the Kodi log is this
2021-06-05 15:55:22.173 T:3608 ERROR <general>: Add-on 'script.module.cherrypy' is not compatible with Kodi
2021-06-05 15:55:22.174 T:3608 ERROR <general>: CAddonInstallJob[script.skin.helper.service]: Die Abhängigkeit auf xbmc.python in Version 2.24.0 konnte nicht aufgelöst werden.
2021-06-05 15:55:22.727 T:3637 INFO <general>: Python interpreter stopped
- Cinemavision
- Special Feautures
- Library Editor Script, i can't finde in your Repo.
- Youtube Bowser
My Picture Database i have installed (V19.0.12), but in den Skin Settings it is shown as "not intsalled"
Thank you for help
I had some time to completely recode addon parts of the skin.
Please try v12.2.36 from my development repo:
https://kodi.wiki/view/Add-on:Rapier#Dev...Repository
That's a development version of the upcoming v 12.3.0 release.
The following scripts are no longer needed and can be uninstalled:
- script.extendedinfo
- script.tv.show.next.aired
- script.youtube.browser
- weather.weatherbit.io
These addons can be installed instead to provide the new functionality:
- script.embuary.info
- script.embuary.helper
- plugin.video.themoviedb.helper
- plugin.video.youtube
- weather.multi
Please test the skin to see if everything works correctly.
