2021-05-29, 07:28
Hi All,
I am running the PlexKodiConnect Add-On on my RaspberryPi with libreelec. Everything is working great for quite some time now..
But, I want to secure my plex account with Two Factor authentication. I see that I can setup easily on the Plex page... But how does this effect my PlexKodiConnect Add-On? As I can see you enable Two Factor with no exclusions, so also PlexKodiConnect is not able to logon then. Is there a way to work around this issue, because on my RPi I do not want to use the two-factor Authentication.. it simply needs to start and work
Any idea how I can setup this up?
