I have Kody v19 on my iMac Big Sur. It is connected to the Fetch Mighty via WiFi through the Telstra modem. Recently I noticed that the library in Movies on Kodi was not updating and was not showing what was on the Fetch. The only thing I can see to do is to click the Update Library item in Options, which does not seem to do anything. Can anyone suggest what I can do to get this working as it was before?
What I have tried:
Clicking Update Library
Removing and re-adding the media source
Adding the IP address to the path
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
I went into Settings and started debugging - then clicked Reboot - thinking it would reboot Kodi only - but of course it rebooted the iMac. When I started Kodi again after the Mac reboot, Fetch once again was displaying everything that it should.
The one thing I didn't try was the reboot of the Mac. You would think I would have tried that, wouldn't you.
Thanks for the help!
