2021-06-01, 14:54
Is there a way to set which menu item Amber starts at? Every time I start up my Shield, Kodi is at the "Settings" menu. I'd like it to start at "Video."
(2021-06-01, 14:54)DrXenos Wrote: [ -> ]Is there a way to set which menu item Amber starts at? Every time I start up my Shield, Kodi is at the "Settings" menu. I'd like it to start at "Video."@DrXenos , yes there is. You need the latest version of Amber from the Amber repo, and you also need script.embuary.helper installed and enabled in your system. The following post explains how to go about it: https://forum.kodi.tv/showthread.php?tid...pid3035700
(2021-06-01, 15:09)bsoriano Wrote: [ -> ](2021-06-01, 14:54)DrXenos Wrote: [ -> ]Is there a way to set which menu item Amber starts at? Every time I start up my Shield, Kodi is at the "Settings" menu. I'd like it to start at "Video."@DrXenos , yes there is. You need the latest version of Amber from the Amber repo, and you also need script.embuary.helper installed and enabled in your system. The following post explains how to go about it: https://forum.kodi.tv/showthread.php?tid...pid3035700
Please let me know if you were able to do what you wanted. Thanks.
Regards,
Bart
