I've set the display I want in settings (Settings / System / Display / Monitor), but often Kodi changes it back to the wrong screen. Happens after I shut down the pc. Suspect it's because monitors get perhaps turned off in a certain order, causing Kodi to switch and then save on close or something...
Any way to force Kodi to a specific screen when starting it? Perhaps a command line option, or like a whitelist for screens just like there is for resolutions or something?
Can't find other solutions through google, only the Settings option, which does not work for me.
Kodi 19.1.0, Windows 10 Pro, 3 screens
You settings are stored in a file called
guisettings.xml this is found within your
Userdata folder see
https://kodi.wiki/view/Userdata
Open file and look for the
videoscreen.monitor setting
In my case this is
xml:
<setting id="videoscreen.monitor">Generic PnP Monitor #1</setting>
Next you need to create a
advancedsettings.xml if you don't already have one, see
https://kodi.wiki/view/Advancedsettings.xml
Within the
advancedsettings.xml you can add entries which force the settings to certain values when Kodi is launched, this is covered in
https://kodi.wiki/view/Advancedsettings....Conversion
So in my case if I wanted Kodi to always start on
Generic PnP Monitor #1 then the
advancedsettings.xml would contain
xml:
<advancedsettings>
<videoscreen>
<monitor>Generic PnP Monitor #1</monitor>
</videoscreen>
</advancedsettings>
(2021-06-11, 10:42)void_foo Wrote: [ -> ]Suspect it's because monitors get perhaps turned off in a certain order, causing Kodi to switch and then save on close
Correct; once you have lost handshaking between the chosen monitor display and PC, Kodi will go to default settings to primary. Exiting Kodi first will save your prefs for next launch as long as the listed displays are still available. The information 'jjd-uk' offered is one of the work-rounds.
Looks like it's working!
For any future googlers, I thought this didn't work at first because I had the wrong monitor in advancedsettings.xml. The number in 'Generic PnP Monitor #1' did not match the number I saw in the Windows Display Settings. Tried different number, was correct one.
