2021-06-12, 15:33
2021-06-12, 15:47
(2021-06-12, 15:33)mansoor10 Wrote: [ -> ]When I install auramod skin this error appears in Kodi 19.1
Please use the built-in menu option for Imgur for uploading your images. Click on the i-button in the menu bar of the text editor, and upload your picture/photo/image.
Your up4.cc links are not working.
2021-06-12, 19:06
(2021-06-12, 15:47)Klojum Wrote: [ -> ](2021-06-12, 15:33)mansoor10 Wrote: [ -> ]When I install auramod skin this error appears in Kodi 19.1
2021-06-12, 19:07
2021-06-12, 19:28
@mansoor10
For Kodi 19 Matrix, you need to use this source: https://github.com/SerpentDrago/skin.aur...ree/Matrix
2021-06-12, 23:29
(2021-06-12, 19:28)Klojum Wrote: [ -> ]@mansoor10
Installed from this source and this error appeared
2021-06-13, 03:43
(2021-06-12, 23:29)mansoor10 Wrote: [ -> ]Installed from this source and this error appeared
Then also report the problem at that Github source: https://github.com/SerpentDrago/skin.auramod/issues
2021-06-22, 14:51
You failed to install a dependency.
Go to https://github.com/SerpentDrago/skin.auramod/wiki
Follow the install instructions.
Then after you install, go back to the wiki and follow the post install instructions.
