I’m totally stumped. I have an Epson 4040 projector, which is capable of handling 4K HDR up to 30hz. It works fine with my Apple TV displaying both 4K and 4K HDR. I get no picture when playing 23.976 content. If I play 1080p with HDR, it outputs as expected. If I play 4K at 23.976hz the screen is black. If I Whitelist 4K with higher refresh rates only, then it outputs picture but the refresh is wrong at 30-50hz. I’m totally stumped. I’ve tried every combination of Whitelisting I can think, but the moment I enable 4K 23.976hz, I get a black screen…
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
newoski why are you posting you question on the "windows" subforum when you are running CoreELEC which is linux?
Thread moved to the Linux subforum.
BTW given that CoreELEC runs modified Kodi you may have better luck asking on CoreELEC own forums.
