2021-06-17, 11:54
Source Code
https://github.com/matthuisman/slyguy.ad...mount.plus
Info & Install Instructions
https://www.matthuisman.nz/2021/06/param...dd-on.html
(2021-06-17, 20:30)matthuisman Wrote: [ -> ]They seem to not be enforcing L1. So all the qualities seem to work everywhere.
When you say HDR10, are you meaning the Dolby Vision content? If says DV next to the quality name. I think a lot of Kodi devices don't support DV yet so maybe that's the issue?
Anyway, I'll push an update with a toggle to enable Dolby Vision (off by default)
(2021-06-17, 23:47)matthuisman Wrote: [ -> ]@WaggThx!!!! Ironic the official app still doesn’t support surround sound on the Shield but your addon does.
Here is the manifest:
https://vod-gcs-cedexis.cbsaavideo.com/i...stream.mpd
Looking at the filenames - the non "DV" H265 streams should actually HDR10+
So you should use them if your device / tv doesn't support Dolby Vision.
I'll add an add-on setting to enable it (disabled by default)
I was wrong thinking DV is backwards compatible.
I think I was thinking of Dolby Atmos
UPDATE:
Just pushed 0.0.7 that adds various audio / video toggles to the add-on settings.
By default - Dolby Vision is off.
You can also turn off 4k, H265, Accessibility Audio, DD, DD+
(2021-06-18, 03:14)matthuisman Wrote: [ -> ]I think iCarly might be enforcing L1 widevine for quality over 1920x1080. I need to use the mobile endpoint (instead of android tv) for playback on windows.
(2021-06-18, 01:10)Wagg Wrote: [ -> ](2021-06-17, 23:47)matthuisman Wrote: [ -> ]@WaggThx!!!! Ironic the official app still doesn’t support surround sound on the Shield but your addon does.
UPDATE:
I will test everything and report back later.
(2021-06-23, 21:15)matthuisman Wrote: [ -> ]I think you'll find iCarly doesn't play on windows though
