2021-06-19, 16:54
When you scroll to the left and go from first movie to last movie, only one poster shows up. Is this normal?
In shelf view, you get about five posters.
(2021-06-19, 16:54)Edworld Wrote: [ -> ]When you scroll to the left and go from first movie to last movie, only one poster shows up. Is this normal?Yes, that’s normal because in Flix view the focus is set on the first position to the left, whereas in Shelf view the focus is on the fifth to the left…
(2021-06-24, 00:48)Edworld Wrote: [ -> ]@manfeedWhen in that screen try pressing left arrow key and then change view to List (even if it seems is already selected)…
I will use my own thread to ask you a question about music.
If I choose Media\Library\manage sources\music and I hit enter, I do not see anything, same behavior is Leia. I believe other skins allow you to choose a drive
(2021-06-24, 01:18)manfeed Wrote: [ -> ](2021-06-24, 00:48)Edworld Wrote: [ -> ]@manfeedWhen in that screen try pressing left arrow key and then change view to List (even if it seems is already selected)…
