Full Version: Preview epggrid from the home window
Hey guys i have looked through the threads and found a few posts of a similar question. But thought i would bring it up again with a few versions higher of kodi.
Is there a way to preview the epggrid from the home screen window. Or create a fake window with 2 fixedlist when a content item gains focus and populate them with 8 channels and there promgrams. Or current channel and 7 above or below. Just to give the apperance of the epggrid on the right. So when onlick happens it opens the actual pvr window.  We can view the pvr stream from the home screen but not the guide..?..This may sound derpy to sOme peOple... ?
depending on your layout conditions
i think you can try creating a panel or list and define your focused layout
using the available info labels 'n' control
(e.g. progress control if ListItem.HasEpg
and some labels https://kodi.wiki/view/InfoLabels#ListItem
ListItem.NextStartTime Start time of the next item (PVR).
ListItem.NextEndTime End of the next item (PVR).
ListItem.NextStartDate Start date of the next item (PVR).
ListItem.NextEndDate End date of the next item (PVR).
Listitem.NextDuration Duration of the next item (PVR). v18
ListItem.ChannelName Channelname of the selected item (PVR).
ListItem.ChannelNumber Channel number of the selected item (PVR).
ListItem.ChannelNumberLabel Channel and subchannel number of the currently selected channel that's currently playing (PVR).
ListItem.Progress Part of the programme that's been played (PVR).
using some native content paths
like
RadioChannels,pvr://channels/radio/
TVChannels,pvr://channels/tv/
matrix supports some other
https://kodi.wiki/view/Opening_Windows_and_Dialogs#PVR
Hi mardukL .. Thanks for the reply. Ill give it a go and see what its like
(2021-06-20, 19:35)moderncolin Wrote: [ -> ]Hi mardukL .. Thanks for the reply. Ill give it a go and see what its like
np.
i am not sure if this control is workin outside of mypvr....xml
https://kodi.wiki/view/EPGGrid_control
but may worth a look...
