Full Version: New structure movie set (sagas) in Kodi 19
Pages: 1 2
Hello everyone!!
I am new to the forum and I have some questions.
-The new file structure of the sagas ... is it final?
-Why this change?
Before I just had to copy the folder to a USB and take it to another Kodi on another device (RBPi 4 or another) ... plug it in ... and I already had everything ... now with the new structure you can't
-Wouldn't it be easier to have all the files in the same folder?
For example:
H:\Movies....................................<source folder>
\---Matrix - Collection (1999-2003)...................................<saga folders>
    +---Matrix (1999)...................................<saga movies>
    |   |   Matrix (1999).mkv
    |   |   Matrix (1999).nfo
    |   |   Matrix (1999)_track3_[spa].srt
    |   |   Matrix (1999)_track4_[eng].srt
    |   \---.actors
    +---Matrix - Reloaded (2003)...................................<saga movies>
    |   |   Matrix - Reloaded (2003).mkv
    |   |   Matrix - Reloaded (2003).nfo
    |   |   Matrix - Reloaded (2003)_track3_[spa].srt
    |   |   Matrix - Reloaded (2003)_track4_[eng].srt
    |   \---.actors
    \---Matrix - Revolutions (2003)...................................<saga movies>
        |   Matrix - Revolutions (2003).mkv
        |   Matrix - Revolutions (2003).nfo
        |   Matrix - Revolutions (2003)_track3_[spa].srt
        |   Matrix - Revolutions (2003)_track4_[eng].srt
        \---.actors
  .nfo files
  <set>
    <name>Matrix - Collection (1999-2003)</name>
    <overview>We are not here because we are free, if we are here it is because we are not</overview>
  </set>
Thanks a lot and sorry for google translator
(2021-06-21, 01:07)HugoCar Wrote: [ -> ]-The new file structure of the sagas ... is it final?
Yes it is for v19 and later. You can read more about it here... https://kodi.wiki/view/Movie_set_information_folder
(2021-06-21, 01:07)HugoCar Wrote: [ -> ]-Wouldn't it be easier to have all the files in the same folder?
No.
You make the assumption that everybody uses movie set folders that contain the movies for the set.
I have movie set folders, but not for all my sets.
Even with the setup you outline in your post, Kodi never worked with that setup. I guess you were using an add-on to make it work.
The new method requires no additional add-ons.
Hi...
This structure was a suggestion in case it was not yet final
Now I use Librelec with Leia 18.9 and AEON Silvo 7.0.9 in RBPi 4 ... with movieset - *. jpg inside the movies folder
Why does the new sagas folder have to have write permissions if I only use "local information only"?
(2021-06-22, 01:32)HugoCar Wrote: [ -> ]Why does the new sagas folder have to have write permissions if I only use "local information only"?
I don't know. It depends on what other add-ons you are using. Where do you see the message that it needs write permission? Does it matter that you give write permission?
Hi...
RBPi4 with folders in PC
My addons are (from Skin AEON NOX Silvo help)
 Skin Shortcuts
 Library Data Provider
 Images Record Labels White
 Images Studios White
 Skin Info Service
 CU LRC Lyrics
 Colorbox Script
 Image Resource Select Addon
 Grab Fanart
From repositories official Kodi and LibreELEC (I don have other)
 addon programs
  Global Search
 addons video
  Missing Movies
  Youtube
When I select the folder in the Menu ... a message appears on the screen saying to select a valid folder and so on until I change the permissions, all other folders are in read mode and I have no problem
For me ... yes ... it is a problem ... I never give permission to write from external devices on my PC (for security)
By the way...
How do I change the date and time from if I don't have internet?
In Regional Menu I only view Unit Formats
Now I use  "date" command from SSH...but when I reboot it gets lost
(2021-06-23, 00:30)HugoCar Wrote: [ -> ]By the way...
The time and date comes from the underlying operating system, not from Kodi. I don't know how to change it in Android or on a RPi, maybe @Klojum or @DarrenHill know, or just do a google search.
As for the other issue, I will need a Debug Log that captures the message you see.
Hi...
I use Raspberry Pi 4 and I have no battery to save time ... when reboot ... it uses the same time settings of the last system installation
Could you have a new menu option to configure manually without requiring additional plugins or internet connection?
Now I don't have it here and it can't make a log ... tomorrow I install LibreELEC-RPi4.arm-9.95.4 again and do it
Raspberry Pi devices do not have something like a CMOS battery (although there are hardware extensions for that IIRC) to keep things like a system timestamp in BIOS memory/firmware. LibreELEC uses NTP time servers to request the current date/time at boot time, but that requires an internet connection. Manually you can set the timestamp via a remote SSH connection, but that also requires some type of network connection...
Hi...
Yes...using SSH...but when I reboot it gets lost
date --set "2021-08-23 08:30"
Now I live in the country and I don't have internet for now
But I think I have solved the time problem by creating an NTP server on the PC
I only need to test from the RBPi...but if I didn't have a pc I couldn't do it
In regional menu options...one option more to configure manually...could be possible?
You can also pick up a simple and small real time clock (RTC) board for the Pi. Then you set the time once (manually or via the internet) and it will keep it going from then onwards.
I have one on my travelling LE Pi, and it works fine. Cost less than $5.
Hi...
@DarrenHill
It's perfect!!...I have buy one now...1€ only!!
The time server from PC run good too
@Karellen
Today it was impossible to make a LOG file with a clean install without updating from 9.2.7 ... but I was able to take a photo
This weekend I will try it
(2021-06-24, 02:09)HugoCar Wrote: [ -> ]but I was able to take a photo
Which exact folder is Kodi trying to write to?
Doublecheck the user permissions on the Windows "server" folders of the Windows user involved.
If it's a directly connected USB disk to the RPi, what is the disk format of the USB drive?
@Klojum
Windows "server" folder's permissions
read & ejecute
lists folder contents
read
enought to read the pics
If you're trying to write to it, you'll need write permissions too
but if I don't want to write anything ... I just want to can select it
Pages: 1 2
