2021-06-22, 10:59
Using Kodi (LibreELEC box) in order to play an ip-camera stream works perfect. I just put the rtsp:// address in a *.strm file and Kodi shows it flawlessly whenever selected to play. However, since I have several (>5) ip-cameras, I would like Kodi to play one RTSP-stream for a specified amount of time, and then switch to the other RTSP-stream for a specified amount of time, and so on. Naturally, I would like to let it loop.
Basically one would just need a simple playlist for this, with RTSP-streams. However, so far I could nowhere find out how to specify to let a live RTSP-stream only play for a specified amount of time (as it is a live stream) and then move on to the next stream in the playlist. So far I know, neither M3U or Kodi's XSP playlist format have options for doing this (which work in Kodi).
Hence, my question is whether anyone know how to create such a playlist (which playlist format?), and if this is not possible within Kodi whether there are any options to do this in any other way?
