2021-06-27, 02:04
2021-06-27, 02:49
Season fanart is not scraped by the scrapers as there is no separation of fanart and season fanart at the online sites.
Some skins can display locally saved season fanart. You can see correct naming in the image here... https://kodi.wiki/view/TV-Show_artwork
Whether this skin displays it, I am not sure. But at least start off by getting the setup correct to check whether it does work.
Also highlight a season in your tv show, call up the context menu, select Manage then select Choose Art. You can manually apply artwork this way.
2021-06-27, 03:11
Thanks for the reply! @Karellen
Season fanarts show up in the default skin. While using Embuary (Matrix), they only show in the "Manage/Choose Art" section. But instead of showing the season fanart, it shows the main fanart.
2021-06-27, 03:14
2021-06-27, 07:40
It should work if you add a new line before this one:
https://github.com/sualfred/skin.embuary...s.xml#L610
<value condition="Container.Content(seasons) + !String.IsEmpty(ListItem.Art(season.fanart))">$INFO[ListItem.Art(season.fanart)]</value>
2021-06-28, 00:45
Thanks for the response @sualfred
I've added the line and code looks like this, not sure if I added the code right-
(Location- \AppData\Roaming\Kodi\addons\skin.embuary-matrix\xml)
Didn't notice any changes on the skin, tried it couple of times, refreshed, deleted cache, thumbnails, etc.
<!-- based on listitems -->
<value condition="Window.IsVisible(script-embuary-video.xml) + !String.IsEmpty(Container(10051).ListItem.Art(fanart))">$INFO[Container(10051).ListItem.Art(fanart)]</value>
<value condition="[Window.IsVisible(DialogVideoInfo.xml) | Window.IsVisible(script-embuary-person.xml)] + !String.IsEmpty(Container(2003).ListItem.Icon) + !Container.OnNext + !Container.OnPrevious">$INFO[Container(2003).ListItem.Icon]</value>
<value condition="[Window.IsMedia | Window.IsVisible(DialogVideoInfo.xml) | Window.IsVisible(DialogMusicInfo.xml) | Window.IsVisible(fullscreeninfo) | Window.IsVisible(pvrguideinfo)] + !String.IsEmpty(ListItem.Art(tvshow.fanart))">$INFO[ListItem.Art(tvshow.fanart)]</value>
<value condition="[Window.IsMedia | Window.IsVisible(DialogVideoInfo.xml) | Window.IsVisible(DialogMusicInfo.xml) | Window.IsVisible(fullscreeninfo) | Window.IsVisible(pvrguideinfo)] + !String.IsEmpty(ListItem.Art(fanart))">$INFO[ListItem.Art(fanart)]</value>
