2021-07-01, 14:18
2021-07-01, 14:25
(2021-07-01, 14:18)micbanand Wrote: [ -> ]Log
2021-07-01 13:58:32.954 T:15088 INFO <general>: Disabled debug logging due to GUI setting. Level 0.
It's not a debug log... Please enable debugging, and restart Kodi, and reproduce the error(s). Provide the new log file, also possible via https://paste.kodi.tv/ .
2021-07-01, 14:50
is this one correct
*Log removed at user's request*
2021-07-01, 17:31
I use opensubtitles.org and subscene.com and they both work as designed on my Matrix set-up.
Of course I'm not using: service.subtitles.napiprojekt v2.0.0 installed; service.subtitles.napisy24pl v3.0.4 installed; service.subtitles.subsceneplus v1.2.9 installed
I should note some of these subtitling sites require registration, although in your case it appears the subtitle is grabbing a .zip instead of an .srt "warehouse-13-second-season_danish-736666.zip" and this could be the stumbling block? The work-round be to manually download the needed sub and just insert it into the file folder. BTW: we like posted logs to be non-edited.
2021-07-01, 18:45
(2021-07-01, 17:31)PatK Wrote: [ -> ]I use opensubtitles.org and subscene.com and they both work as designed on my Matrix set-up.
Thanks. folder did contain .srt and the .zip Simply deleted the .zip and now its stable. Must be a bug! because have worked Earlier. I Guess before stable 19
Can someone please delete log in #3 it is not cleaned.
link in #1 Should be?
Again thanks.
2021-07-01, 19:32
(2021-07-01, 18:45)micbanand Wrote: [ -> ]Can someone please delete log in #3 it is not cleaned.
Not sure which part of the log wasn't cleaned, but the link is removed.
2021-07-01, 21:02
Thread marked solved.
