I tried to update my library today but all the movies show no poster and they cannot be added via "information/..."... I deleted an older movie and updated library again. And the old film with poster was added without a poster. So i see there is an error with downloading the pictures from tmdb.
i have the same problem on a raspberry pi 3, 4 and also on windows.
any suggestions?
using latest kodi (19.1 matrix)
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
