Full Version: Aeon Tajo - PVR (Recording Status) Infoline
Hi Manfeed,
Nice work on this skin, it's looking very polished. The RGB affect kinda matches the "Colour Shift" effect I have setup in Corsair's iCue software.
Smile
Couple of quick issues spotted to report though:
It seems the "Bold" tags for PVR active recordings are not being rendered properly in Tajo (This infoline item displays as intended in the other skins I currently have installed), and at the moment, the current time (top-left) is overlapped by the RSS feed. It might look better if the space for the clock is reserved, much like you've done with the RSS logo on the right-hand-side, here.
Keep up the good work.
Smile
Dan / Gib.
(2021-07-02, 21:31)gibxxi Wrote: [ -> ]Hi Manfeed,
Smile
Smile
Dan / Gib.
Thanks! It should be already fixed in github...
(2021-07-03, 14:43)manfeed Wrote: [ -> ]
Smile
Smile
Dan / Gib.
Hi Manfeed, thanks for the info. Will sync from there then.
Smile
Dan / Gib.
