(2021-07-26, 22:54)moserroger Wrote: [ -> ]Hi bsoriano
Unfortunately I overread before that you are the maintainer of Amber.
It's nice that you took the time to reply. And that you offered to have a look at Black Glass Nova. I found it a very nice feature to be able to customize the bootup screen. I don't know if it shouldn't also be possible through the "Splash screen method" (Splash in Kodi Forum) may be even independent of the current skin?
The fanart for the music work. Thanks.
Cheers,
moses
moserroger , I was able to figure it out, with some help. Thank you for asking for this.
If you are able to download and update from GitHub, the changes are already there:
https://github.com/bartolomesoriano/skin...master.zip
I added a new setting in the Advanced section of the skin settings, that allows you to choose what you want for the startup background:
When you select that, Amber shows you the available options: Single Image, Multiple Images, A video (or video or music playlist), and Skin Default, which means no startup background. The selection dialog looks like this:
If you choose single image, you can browse for the image that you want. Amber starts the browse dialog in the backgrounds/intro skin folder, in which I have added 5 images to choose from. You can of course go to any location accessible to your Kodi machine to look for the image that you want. It looks like this:
If you choose Multiple Images, you can browse for the folder that contains the images. Amber starts the browse dialog again in the backgrounds/intro skin folder. If you choose this folder, Amber will cycle through the images on startup. Again, you can browse to any folder that is accessible to your Kodi machine. It looks like this initially:
If you choose Video/Playlist, Amber will open a browser dialog so that you can look for the video file/playlist that you want. It is important to note that Amber accepts files with the following extensions: .mp4|.avi|.mkv|.xvid|.wmv|.mov|.xsp|.mp3|.wma|.flac|.m3u. The browser dialog starts in the extras/intro skin folder, where I am including an intro video that you can use. Of course, you can browse to any location that is accessible to your Kodi machine to look for the video/playlist file. It looks like this initially:
Just so that you are aware, it is not possible, as far as I know, from the skin side, to stop the default Kodi splash image from appearing briefly. It will show for less than a second, and then the startup image(s) or video/playlist that you have chosen will show.
If you choose Single Image, the image will show for about 3 seconds. If you choose Multiple Images, the images will show for about 8 seconds, so that more than one image can be seen. If you choose Video/Playlist, the video/playlist will play for about 12 seconds, which is the length of the startup video that I am including with the skin.
Please note that if you choose a startup video/playlist that is longer than 12 seconds, it will be cut off after that interval, and the home window will show.
Let me know if you are able to test this from GitHub, and if this is what you were looking for. Thanks.
Regards,
Bart
