Full Version: Poster Wall not "popping up" information?
Recently upgraded to Matrix and AuraMOD v19. However when I set the view type to "Poster Wall" it just displays a static poster, in previous versions after leaving it on an entry for a few seconds (which you could customise) it would pop up the series/movie description. Is there any way to re-enable this feature?
Personally, I can't remember the poster wall viewtype doing that in any version or AuraMod, but there are a lot of settings for this skin so I could be wrong.
You might have better luck posting this question in the issue tab over at:
https://github.com/SerpentDrago/skin.aur...ree/Matrix
Following this might help as well:
https://github.com/SerpentDrago/skin.auramod/wiki
@bloott @Uthred
Please report issues here:
https://github.com/SerpentDrago/skin.auramod/issues
Might help if you post pictures of what you mean so that it's easier to understand/faster to fix.
As well make sure you're on the most up to date version, same with dependencies.
