2023-03-29, 22:35
Hey there - might be a silly question, but the link for the 20.0 tar does not seem to be working anymore (worked great a month or so ago!). Any chance 20.1 is out there someplace?
(2023-03-29, 22:35)talon2k3 Wrote: [ -> ]Hey there - might be a silly question, but the link for the 20.0 tar does not seem to be working anymore (worked great a month or so ago!). Any chance 20.1 is out there someplace?
(2023-04-06, 23:28)TheJezstarr Wrote: [ -> ]As an aside, we really shouldn't be directing people to dmo anyway. It WILL break your system.
libva info: VA-API version 1.17.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_17
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.17 (libva 2.12.0)
vainfo: Driver version: Intel iHD driver for Intel® Gen Graphics - 23.1.1 ()
vainfo: Supported profile and entrypoints
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : VAEntrypointStats
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSliceLP
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSliceLP
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSliceLP
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileHEVCMain10 : VAEntrypointEncSliceLP
VAProfileVP9Profile0 : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointEncSliceLP
VAProfileVP9Profile1 : VAEntrypointVLD
VAProfileVP9Profile1 : VAEntrypointEncSliceLP
VAProfileVP9Profile2 : VAEntrypointVLD
VAProfileVP9Profile2 : VAEntrypointEncSliceLP
VAProfileVP9Profile3 : VAEntrypointVLD
VAProfileVP9Profile3 : VAEntrypointEncSliceLP
VAProfileHEVCMain12 : VAEntrypointVLD
VAProfileHEVCMain422_10 : VAEntrypointVLD
VAProfileHEVCMain422_12 : VAEntrypointVLD
VAProfileHEVCMain444 : VAEntrypointVLD
VAProfileHEVCMain444 : VAEntrypointEncSliceLP
VAProfileHEVCMain444_10 : VAEntrypointVLD
VAProfileHEVCMain444_10 : VAEntrypointEncSliceLP
VAProfileHEVCMain444_12 : VAEntrypointVLD
VAProfileHEVCSccMain : VAEntrypointVLD
VAProfileHEVCSccMain : VAEntrypointEncSliceLP
VAProfileHEVCSccMain10 : VAEntrypointVLD
VAProfileHEVCSccMain10 : VAEntrypointEncSliceLP
VAProfileHEVCSccMain444 : VAEntrypointVLD
VAProfileHEVCSccMain444 : VAEntrypointEncSliceLP
VAProfileAV1Profile0 : VAEntrypointVLD
VAProfileHEVCSccMain444_10 : VAEntrypointVLD
VAProfileHEVCSccMain444_10 : VAEntrypointEncSliceLP
General
Complete name : Sparks-5994fps-AV1-10bit-1920x1080-2194kbps.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : iso4 (iso4/av01)
File size : 60.1 MiB
Duration : 9 min 11 s
Overall bit rate : 915 kb/s
Encoded date : UTC 2022-06-09 03:25:48
Tagged date : UTC 2022-06-09 03:25:48
Writing application : GPAC-2.1-DEV-rev199-g8e29f6e8b-github_master
Video
Format : AV1
Format/Info : AOMedia Video 1
Format profile : [email protected]
Codec ID : av01
Bit rate : 914 kb/s
Maximum bit rate : 6 376 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.018
Stream size : 60.1 MiB (100%)
Title : [email protected]_master
Tagged date : UTC 2022-06-09 03:25:49
Color range : Limited
Codec configuration box : av1C
2023-04-07 19:09:32.900 T:2823 info <general>: VideoPlayer::OpenFile: /mnt/seed0/Movies/Sparks-5994fps-AV1-10bit-1920x1080-2194kbps.mp4
2023-04-07 19:09:32.900 T:5344 warning <general>: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
2023-04-07 19:09:32.900 T:5344 info <general>: Creating InputStream
2023-04-07 19:09:32.925 T:5344 info <general>: Creating Demuxer
2023-04-07 19:09:32.988 T:5344 info <general>: Opening stream: 0 source: 256
2023-04-07 19:09:32.988 T:5344 info <general>: [WHITELIST] Searching the whitelist for: width: 1920, height: 1080, fps: 25.000, 3D: false
2023-04-07 19:09:32.989 T:5344 info <general>: Display resolution ADJUST : 3840x2160 @ 50.000000 Hz (27) (weight: 0.000)
2023-04-07 19:09:33.307 T:2823 info <general>: VideoPlayer: OnLostDisplay received
2023-04-07 19:09:33.307 T:2823 warning <general>: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2023-04-07 19:09:33.307 T:2823 warning <general>: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
2023-04-07 19:09:33.312 T:2823 info <general>: GL: Maximum texture width: 16384
2023-04-07 19:09:33.313 T:5344 info <general>: Creating video codec with codec id: 226
2023-04-07 19:09:33.313 T:5344 info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: Alliance for Open Media AV1
2023-04-07 19:09:33.313 T:5344 info <general>: Creating video thread
2023-04-07 19:09:33.314 T:5346 info <general>: running thread: video_thread
2023-04-07 19:09:33.324 T:2823 error <general>: CDRMAtomic::DrmAtomicCommit - test commit failed: (Invalid argument) - falling back to last successful atomic request
Object: plane ID: 40
Property: FB_ID ID: 17 Value: 208
Object: crtc ID: 80
Object: connector ID: 199
2023-04-07 19:09:33.324 T:2823 error <general>: CDRMAtomic::DrmAtomicCommit - atomic commit failed: Invalid argument
2023-04-07 19:09:36.319 T:2823 info <general>: VideoPlayer: OnResetDisplay received
2023-04-07 19:09:36.319 T:2823 warning <general>: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2023-04-07 19:09:36.319 T:2839 info <general>: Skipped 1 duplicate messages..
2023-04-07 19:09:36.319 T:2839 info <general>: CActiveAESink::OpenSink - initialize sink
2023-04-07 19:09:36.319 T:2839 info <general>: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=PCH,DEV=0"
2023-04-07 19:09:36.329 T:5347 info <general>: COutput::OnStartup: Output Thread created
2023-04-07 19:09:36.329 T:5347 warning <general>: VAAPI::SupportsFilter image format not NV12
2023-04-07 19:09:36.363 T:5346 error <general>: GetPicture - avcodec_receive_frame returned failure
2023-04-07 19:09:36.364 T:2839 info <general>: CAESinkALSA::Initialize - Opened device "hdmi:CARD=PCH,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00"
2023-04-07 19:09:36.364 T:2839 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-04-07 19:09:36.364 T:2839 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
2023-04-07 19:09:36.365 T:5346 error <general>: GetPicture - avcodec_receive_frame returned failure
Thread 103 "VideoPlayer" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fff3dbf46c0 (LWP 1341)]
0x00007ffff5bc8688 in ?? () from /lib/x86_64-linux-gnu/libavcodec.so.59
If you dont have function names in the "bt full" output, you need to install debug symbols folowiing this guide https://wiki.debian.org/HowToGetABacktrace and retry getting bt full.shell:export DEBUGINFOD_URLS="https://debuginfod.debian.net"gdb -p $(pidof kodi.bin)# reproduce the crashbt full
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
0x00007f639d88b345 in __GI___clock_nanosleep (clock_id=clock_id@entry=0, flags=flags@entry=0, req=0x7fff7541c800, rem=0x7fff7541c800) at ../sysdeps/unix/sysv/linux/clock_nanosleep.c:48
Download failed: Argument invalide. Continuing without source file ./time/../sysdeps/unix/sysv/linux/clock_nanosleep.c.
48 ../sysdeps/unix/sysv/linux/clock_nanosleep.c: Aucun fichier ou dossier de ce type.
Thread 91 "VideoPlayer" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fff977fe6c0 (LWP 5827)]
0x00007ffff5bc8688 in skip_mode_params (s=0x55555cc413c0) at src/libavcodec/av1dec.c:273
Download failed: Invalid Argument. Continuing without source file ./debian/standard/src/libavcodec/av1dec.c.
273 src/libavcodec/av1dec.c: No such file or directory.
shell:
ffplay -i Sparks-5994fps-AV1-10bit-1920x1080-2194kbps.mp4
ffplay version 5.1.2-3 Copyright © 2003-2022 the FFmpeg developers
built with gcc 12 (Debian 12.2.0-14)
configuration: --prefix=/usr --extra-version=3 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --disable-sndio --enable-libjxl --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared
libavutil 57. 28.100 / 57. 28.100
libavcodec 59. 37.100 / 59. 37.100
libavformat 59. 27.100 / 59. 27.100
libavdevice 59. 7.100 / 59. 7.100
libavfilter 8. 44.100 / 8. 44.100
libswscale 6. 7.100 / 6. 7.100
libswresample 4. 7.100 / 4. 7.100
libpostproc 56. 6.100 / 56. 6.100
error: XDG_RUNTIME_DIR is invalid or not set in the environment.
[libdav1d @ 0x7f6734002680] libdav1d 1.0.0 0KB sq= 0B f=0/0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/mnt/seed0/Movies/Sparks-5994fps-AV1-10bit-1920x1080-2194kbps.mp4':
Metadata:
major_brand : iso4
minor_version : 1
compatible_brands: iso4av01
creation_time : 2022-06-09T03:25:48.000000Z
encoder : GPAC-2.1-DEV-rev199-g8e29f6e8b-github_master
Duration: 00:09:11.00, start: 0.000000, bitrate: 915 kb/s
Stream #0:0[0x1](und): Video: av1 (Main) (av01 / 0x31307661), yuv420p10le(tv), 1920x1080, 914 kb/s, 25 fps, 25 tbr, 25k tbn (default)
Metadata:
handler_name : [email protected]_master
vendor_id : [0][0][0][0]
[libdav1d @ 0x7f6734008100] libdav1d 1.0.0
27.49 M-V: 0.000 fd= 0 aq= 0KB vq= 373KB sq= 0B f=0/0
