Full Version: Error of translation french msgctxt "#38026"
Hello, I just found an error of translation but I am not sure, when you display the directors list by clicking on the directors icon from the home screen, it is written for every directors their number of appearances (which means if I am not wrong the number of movie a director has directed). It is translated in french as "Apparences" which means in english "Appearances" but the other definition of appearances : "the way that someone or something looks."
So here in french it should be instead of "Apparences" : "Apparitions" for "Appearances" or "Nombre d'apparitions" for "Number of appearances"
Hi @Bungee_G
Thanks for reporting the translation issue.
I think I found the correct string.
I have corrected it here: https://github.com/xbmc/repo-resources/p...2696d30f00
Please check if it's correct.
It will be a short while before the language addons are updated.
You are more than welcome to sign up at Weblate (if you haven't already).
(2021-07-19, 00:22)Gade Wrote: [ -> ]Hi @Bungee_G
Yes, it's correct, thanks.
Great, I'll mark this thread as solved. Smile
