Full Version: Cosmic
A season/episode view would be excellent
(2021-08-11, 00:14)CollotsSpot Wrote: [ -> ]A season/episode view would be excellent
heppen:
have a look here for Episode view. Maybe it needs a little adjustments
https://github.com/louisbraun/skin.unfus...isodes.xml
and maybe EstuaryMod v2 has some nice views also
(2021-08-11, 11:57)Solo0815 Wrote: [ -> ]
heppen:
Thanks, I will look into it if need inspiration Smile
Heppen,
In the large list view, the background seems to be divided in 2 parts. The left panel is lighter. The fanart seems to be divided in 2. Can you set both panel have the same darkness? The fanart in the background is more continuous.
I like this skin very much.
Thank you Big Grin
(2021-08-12, 13:14)chitridang Wrote: [ -> ]Heppen,
Thank you Big Grin
Hey,
Could you please show me on a screenshot what you mean? Smile
(2021-08-12, 14:44)nfm886 Wrote: [ -> ]
Thank you Big Grin
Hey,
(2021-08-13, 01:48)chitridang Wrote: [ -> ]
Thank you Big Grin
Hey,
How can I add the screenshot in this reply? It is stored in my PC... Sad
(2021-08-13, 02:10)chitridang Wrote: [ -> ]https://www.mediafire.com/view/1jhqee7t2...Y.jpg/file
https://www.mediafire.com/file/9cgq1odqh...2.jpg/file
Oh, I see. I will consider this when adding new view types Smile
(2021-08-13, 09:03)nfm886 Wrote: [ -> ]
Thanks. I'm nearsighted and I have changed the font size of the list to be able to see clearly Cool
(2021-08-13, 11:20)chitridang Wrote: [ -> ]
At least we know, changing font sizes works properly ^^
May I kindly ask you if you have already made it possible to select your own background?
(2021-08-13, 12:12)Aaiemron Wrote: [ -> ]May I kindly ask you if you have already made it possible to select your own background?
Not yet. But today I was looking into this task Smile
I'm gonna see if it's hard to implement, if no, I will add this option today.
(2021-08-13, 12:15)nfm886 Wrote: [ -> ]
Thank you very much
(2021-08-13, 12:16)Aaiemron Wrote: [ -> ]
Thank you very much
Ok, just added this option. Now, you can set background for each menu entry:
Please download this zip file: https://github.com/nfm886/skin.cosmic/ar...master.zip and do some tests... Waiting for your feedback!
