Full Version: Cosmic
(2021-08-13, 12:32)nfm886 Wrote: [ -> ]
(2021-08-13, 12:16)Aaiemron Wrote: [ -> ]
(2021-08-13, 12:15)nfm886 Wrote: [ -> ]Not yet. But today I was looking into this task Smile
I'm gonna see if it's hard to implement, if no, I will add this option today.
Thank you very much
Ok, just added this option. Now, you can set background for each menu entry:
Please download this zip file: https://github.com/nfm886/skin.cosmic/ar...master.zip and do some tests... Waiting for your feedback!
Just tested this, working perfectly, have different backgrounds for all categories 😊
(2021-08-13, 13:32)Criddler23 Wrote: [ -> ]
(2021-08-13, 12:16)Aaiemron Wrote: [ -> ]Thank you very much
Awesome. Now just add the option to set global background Smile
Thank you very much
It's working great!
Thanks a lot for adding this option.
I have Arctic: Zephyr 2 - Resurrection installed, what is the difference between them? Both look similar.
(2021-08-13, 16:15)iMak Wrote: [ -> ]I have Arctic: Zephyr 2 - Resurrection installed, what is the difference between them? Both look similar.
They are basically 2 different skins with similar look. I just made Cosmic to looks similar because I think some people liked it.
In the near future, I will add some more layouts, so look will change. For now there is Vertical and Horizontal layout.
I can't tell you all the differences. Just install it and you will notice them Wink
#edit
btw. Keep in mind, Cosmic is still in early stage of development. However you can use it without issues Wink
Got it, I trust your taste  Wink
(2021-08-13, 16:39)iMak Wrote: [ -> ]Got it, I trust your taste  Wink
Thanks Smile
If you will use it and found any bug please give me a feedback!
hey @nfm886 loving your skin. thank you very much!
is there anyway to add option move the clearlogo to the right ?
(2021-08-13, 17:01)kucas Wrote: [ -> ]hey @nfm886 loving your skin. thank you very much!
Hey, thanks! Smile
Maybe I can add this but.. where? ^^ There is couple of places where clearlogo is appear. Screenshot would be appreciated Smile
(2021-08-13, 17:24)nfm886 Wrote: [ -> ]
Hey, thanks! Smile
https://imgur.com/5mzMVJm just on the main page of the skin
(2021-08-13, 17:48)kucas Wrote: [ -> ]
Hey, thanks! Smile
I see. I'm not sure if I want to add this option but we will see ^^
btw.
Just pushed an update. This time it contains many fixes and additions.
Please check this changelog:
Added: Option to set Global Background
Added: Option to Enable/Disable online ratings
Fixed: Lacks of highlight colours in some places [x2]
Added: Initial option to set background for each menu entry
Fixed: DialogBusy.xml when BG Trailers are enabled
Fixed: Background trailers condition
Added: Auto-completion for Virtual Keyboard
Fixed: Info Line Label about currently selected Episode in widgets
As you can see, I added option to enable/disable ratings. It's disabled by default. Not everyone likes it, and not everyone has configured OMDb API key... If your ratings disappeared (and it does^^) please go to skin settings > library > choose ratings and enable what ratings you would like.
(2021-08-13, 16:24)nfm886 Wrote: [ -> ]
#edit
If you need ideas for pvr please look att Unfussy skin . Some great views like this one
https://imagizer.imageshack.com/img922/6762/QUyR3g.png
(2021-08-13, 20:24)Jönke Wrote: [ -> ]
#edit
Thanks. You are second person who recommending look into that direction Tongue
To be honest, I'm happy with current state of PVR. Maybe in the future I will add new views and then I will see Unfussy skin Smile
Hi can you add option to disable auto scrolling plot for home widgets
@nfm886  I'm having a problem with ratings. If i select top 250 only, nothing shows. If I select imdb, only logo shows. If I select imdb user votes, nothing shows unless i use imdb as well but then I get both rating and user votes. I would like to be able to get rating without user votes and also be able to see top 250.
Hope that all makes sense.
