Full Version: Cosmic
(2021-08-14, 09:25)Blackysb Wrote: [ -> ]@nfm886  I'm having a problem with ratings. If i select top 250 only, nothing shows. If I select imdb, only logo shows. If I select imdb user votes, nothing shows unless i use imdb as well but then I get both rating and user votes. I would like to be able to get rating without user votes and also be able to see top 250.
Hope that all makes sense.
Oh, i see. Just tested it right now, and you are right Smile
Gonna fix it.
Ok, fixed it. If you would like to test, please download this zip file: https://github.com/nfm886/skin.cosmic/ar...master.zip
Goodmorning.
Auto play trailers is still WIP, I assume?
(2021-08-14, 10:18)nfm886 Wrote: [ -> ]
That's fixed the imdb rating but still not showing top 250?
(2021-08-14, 10:52)Aaiemron Wrote: [ -> ]Goodmorning.
Yeah. They are working, so you can test it on your own, but it require some future improvements. For now, I don't want to touch it too much since it works in most cases.
(2021-08-14, 11:03)Blackysb Wrote: [ -> ]
From what i tested it worked...
(2021-08-14, 11:55)nfm886 Wrote: [ -> ]
Oke, but how to enable trailers?
The setting is greyed out as you can see:
(2021-08-14, 12:41)Aaiemron Wrote: [ -> ]
You need YouTube add-on installed and enabled. Also it's good to be logged in, so you can play trailers from YouTube as well.
I did not tested it without YouTube add-on, however it should play local trailers just fine from what I saw.
Would be nice to see what's happen when you will enable this option without being logged in YouTube Big Grin
With the Youtube addon enabled I can play only local movie trailers, not TV show trailers.
It says: "nothing to play" although I have TV show trailers in the folders. (In ressurection they played)
But it's not a big deal. Thank you
(2021-08-14, 13:50)Aaiemron Wrote: [ -> ]With the Youtube addon enabled I can play only local movie trailers, not TV show trailers.
Yeah. In resurrection I was using TMDb helper to play trailers as well. Here I'm using only PlayMedia() which Kodi itself manages how to play it.
It's better to see "Nothing to play" than crash or error message Big Grin However I will try to improve it in near future. Hope to sort it out as much as I can.
(2021-08-14, 14:08)nfm886 Wrote: [ -> ]
Thank you for answering and explaining.
Great work so far.
(2021-08-14, 11:57)nfm886 Wrote: [ -> ]
(2021-08-14, 10:18)nfm886 Wrote: [ -> ]Ok, fixed it. If you would like to test, please download this zip file: https://github.com/nfm886/skin.cosmic/ar...master.zip
Tried it on both android and windows, I only get the rating not the top 250 #, can someone else confirm I'm not going mad lol
(2021-08-14, 16:54)Blackysb Wrote: [ -> ]
(2021-08-14, 11:03)Blackysb Wrote: [ -> ]That's fixed the imdb rating but still not showing top 250?
Just pushed an update with this fix from earlier. You can test it again from heppen's repository.
Also, tested it on another device, and... it works^^
Does it works for you? ^^
I'm currently working on new home layout: https://streamable.com/v0tbk8
#edit
Background trailers will be working too: https://streamable.com/knuj2b Smile
The classic vertical layout is great for people who like fullscreen fanart. Like me
