Full Version: Cosmic
(2021-08-15, 11:06)Aaiemron Wrote: [ -> ]The classic vertical layout is great for people who like fullscreen fanart. Like me
Yeah, that's why it's become default layout from now Smile
Little feature for PVR users: https://streamable.com/wufczd Big Grin
Also Classic layout: https://streamable.com/g4ji1k
(2021-08-14, 19:35)nfm886 Wrote: [ -> ]
(2021-08-14, 16:54)Blackysb Wrote: [ -> ]
(2021-08-14, 11:57)nfm886 Wrote: [ -> ]From what i tested it worked...
Tried it on both android and windows, I only get the rating not the top 250 #, can someone else confirm I'm not going mad lol
Does it works for you? ^^
I'm currently working on new home layout: https://streamable.com/v0tbk8
#edit
Background trailers will be working too: https://streamable.com/knuj2b Smile
No luck at my end. I tried deleting skin and skin settings also deleted simplecache db and textures 13. Still the same only get rating.
Install from repo fails for me.
2021-08-15 19:12:28.658 T:11228   ERROR <general>: CCurlFile::Open failed with code 404 for https://raw.github.com/nfm886/repository...1.0.13.zip:
(2021-08-15, 20:15)dm21912 Wrote: [ -> ]Install from repo fails for me.
That is a dead link, the ones in the OP should work fine though.
Hey thanks again for the hard work on this brilliant skin!
Multi global background doesn't work for me. Once I select a folder containing images the background stays black
Please check for updates before. It's trying to install old version instead of the latest one.
(2021-08-15, 21:38)CollotsSpot Wrote: [ -> ]Hey thanks again for the hard work on this brilliant skin!
Oh right. I forgot about it. Will try to fix it soon Smile
#edit
Ok, it's fixed already in latest master branch. Will be available with today's update Smile
Hey thanks for making this skin. You literally work on this every day which shows how much you care about this, which is awesome!
One request I have is, if possible, to make a secondary small menu in vertical layout that will show settings, add-ons and power options.
This will be useful for regular users in order to focus only on main menu which typically is tv shows and movies.
(2021-08-16, 08:54)mashrouman Wrote: [ -> ]One request I have is, if possible, to make a secondary small menu in vertical layout that will show settings, add-ons and power options.
I'm not sure how it should works? Screenshot would be appreciated Smile
(2021-08-16, 09:14)nfm886 Wrote: [ -> ]
Yeah sorry. I will bring Titan Bidgie Mod here as an example (I know you said you are making something unique but that is the only skin I know that has this feature). The menu here looks broken because I switch off the cosmic skin just to take this screenshot.
(2021-08-16, 09:26)mashrouman Wrote: [ -> ]
Oh, I see.
I don't know if I want to add this feature Big Grin If so, I see it in different place. Under the "Switch Profile" with button called "Common shortcuts". And then it will open context menu with those shortcuts.
Hello.
Would you consider to move the menubar all the way to the left with icons only?
And if possible the name of the selected menu item in the top left as shown in this image:
Thank you
(2021-08-16, 11:36)Aaiemron Wrote: [ -> ]Hello.
Thank you
You mean Classic layout?
(2021-08-16, 11:41)nfm886 Wrote: [ -> ]
Thank you
Yes
