Full Version: Cosmic
(2021-08-18, 19:20)Aaiemron Wrote: [ -> ]Can you please add an option to show the number of unwatched or new episodes in the top corner on the left or the right in a tvshow widget?
Sure, I will add them. Just don't know when. Now I'm planning to add few view types to library.
Maybe in the meantime I will add them.
(2021-08-18, 19:23)nfm886 Wrote: [ -> ]
You're the best. Thanks
Also possible to show in widgets if a file is available in local library? So not only unwatched episodes? Arctic Horizon is a good example..
Hey im having a problem with your repo because as soon as I try to access it, it tells me that it 'could not connect to repository'. What do i do now?
(2021-08-19, 04:16)swanov Wrote: [ -> ]Hey im having a problem with your repo because as soon as I try to access it, it tells me that it 'could not connect to repository'. What do i do now?
I guess you are not using Kodi 19+. My repo is compatible with only Matrix and above.
(2021-08-18, 19:59)Aaiemron Wrote: [ -> ]
Added those indicators: https://imgur.com/gallery/WAnuJPI
Quote:Also possible to show in widgets if a file is available in local library? So not only unwatched episodes? Arctic Horizon is a good example..
Sure. Please show me how it should looks like. I installed AH skin but did not see any indicators...
(2021-08-19, 08:55)nfm886 Wrote: [ -> ]Added those indicators: https://imgur.com/gallery/WAnuJPI
Amazing! Are they already implemented?
(2021-08-19, 09:37)Aaiemron Wrote: [ -> ]
Yes. You can test it from now.
(2021-08-19, 09:49)nfm886 Wrote: [ -> ]Yes. You can test it from now.
They look perfect. Thanks a lot
(2021-08-19, 09:55)Aaiemron Wrote: [ -> ]
Good Smile
Now let's wait for @Rijs43 and see what we can do with library indicators Smile
(2021-08-19, 10:03)nfm886 Wrote: [ -> ]
Good Smile
I mean as in the link. When you have a widget from TMDBhelper, lets say Popular, the posters are having a square icon on the right upper corner of the posters to indicate the file is available in your local library and you are able to watch.
TMDBhelper local library indicator
Hope this makes it more clear.
(2021-08-19, 10:16)Rijs43 Wrote: [ -> ]
(2021-08-19, 09:55)Aaiemron Wrote: [ -> ]They look perfect. Thanks a lot
Good Smile
Ok, I see. I will see what I can do Smile
(2021-08-19, 10:20)nfm886 Wrote: [ -> ]
(2021-08-19, 10:03)nfm886 Wrote: [ -> ]Good Smile
That would be really great and deserves a coffee Big Grin
After the latest update I got these strange numbers:
​​​​​​Image
(2021-08-19, 10:46)Aaiemron Wrote: [ -> ]After the latest update I got these strange numbers:
​​​​​​Image
Oh damn. Beautify removed spacing... I will fix it, thanks!
#edit
Ok, it's fixed. btw. These numbers are version of the installed dependencies Smile
