Full Version: Cosmic
Any plan to add this view
https://i.imgur.com/Ze25F1L.jpg
(2021-07-30, 17:53)trkselim Wrote: [ -> ]Any plan to add this view
Do you mean that title near the widget name? Maybe as an option Smile
(2021-07-30, 18:11)nfm886 Wrote: [ -> ]
No i mean the view
(2021-07-30, 18:21)trkselim Wrote: [ -> ]
No i mean the view
Ah ok Smile
Then yes, I'm planning to add some other views, maybe one of them similar to this one you showed Smile
P.S. Just added Blur option, short presentation: https://streamable.com/8wea0o Big Grin
(2021-07-30, 18:27)nfm886 Wrote: [ -> ]
(2021-07-30, 18:11)nfm886 Wrote: [ -> ]Do you mean that title near the widget name? Maybe as an option Smile
No i mean the view
Ah ok Smile
If I disable blur it will be full screen fan art
(2021-07-30, 18:39)trkselim Wrote: [ -> ]
(2021-07-30, 18:21)trkselim Wrote: [ -> ]No i mean the view
Ah ok Smile
Just like at the beginning of the video. There will be black vignette. Without it, everything would be hard to read.
Blur with fanart window would be a nice addition, like how AZ:Reloaded does it:
(2021-07-30, 18:43)nfm886 Wrote: [ -> ]
(2021-07-30, 18:27)nfm886 Wrote: [ -> ]Ah ok Smile
Maybe instead of vignette/black, you can blur the left side of the fanart and show only the right of it? Would be cool I think.. or maybe just a blur effect (faded) instead of a black colour?
(2021-07-30, 19:08)FXB78 Wrote: [ -> ]Blur with fanart window would be a nice addition, like how AZ:Reloaded does it:
He he, I like your thinking Smile
I will see if I can implement this Smile
[quote="nfm886" pid='3052078' dateline='1627665915']
Maybe similar to this.. great blur at the bottom of the image.. but instead of bottom at the left in flix view. Just to give you an idea of what I meant with blur..
(2021-07-30, 19:19)Rijs43 Wrote: [ -> ]
This will look great 👍🏻
Just added widget movement animation from AZ2: Resurrection: https://streamable.com/ouqsim Smile
(2021-07-30, 20:22)nfm886 Wrote: [ -> ]Just added widget movement animation from AZ2: Resurrection: https://streamable.com/ouqsim Smile
Getting better and better Big Grin
Good morning.  A little question: Does this skin get an autoclose OSD option?
thank you
