Full Version: Cosmic
(2021-09-02, 11:56)Criddler23 Wrote: [ -> ]
(2021-09-02, 11:24)Rijs43 Wrote: [ -> ]
(2021-09-02, 11:22)Criddler23 Wrote: [ -> ]I use YouTube with my own API, but for tv series tubed takes over, I donโ€™t know how to override it?
I believe there is a setting in Information Providers whether to play with YT or Tubed.
Otherwise just delete Tubed and see if this works for you.
Thank you, Iโ€™ll have a look later ๐Ÿ˜Š
Edit Just removed Tubed from the scraper settings, it has it as default.Using You Tube, trailers working again.Many thanks for the help ๐Ÿ‘๐Ÿป
Glad to hear that worked for you Smile
(2021-09-02, 13:09)nfm886 Wrote: [ -> ]
(2021-09-02, 12:10)Rijs43 Wrote: [ -> ]
(2021-09-02, 12:10)Rijs43 Wrote: [ -> ]Cheers my friend.
Yes I can test for you.
FYI - someone earlier mentioned to show the next pages of TMDBhelper on home screen instead of leaving home screen. Might help you to look at AutoWidget as this works quiet well with next and previous pages.
Edit: we're can I find ZIP?
https://github.com/nfm886/skin.cosmic/ar...master.zip
My current implementation is not the best. Working on better one.
(2021-09-02, 11:33)nfm886 Wrote: [ -> ]
(2021-09-02, 11:26)Rijs43 Wrote: [ -> ]Hi @nfm886
In your latest update I can see you deleted an extra font, however with Default and Arial the info on home is quiet large in my opinion and really liked the condensed Font. Also The name of the widget is not Bold any more.
I removed extra fonts except Arial's because handling them all is kind of harder than only 3. However I'm not done yet with fonts so things will be different soon Smile
btw. Meanwhile added option to match overlay colour to image. Would you like to test it?
Cheers my friend.
Ok, I fixed it a little bit. Please re-download zip and do some more tests Wink
I will look into it, thanks.
(2021-09-02, 16:02)nfm886 Wrote: [ -> ]
(2021-09-02, 11:33)nfm886 Wrote: [ -> ]I removed extra fonts except Arial's because handling them all is kind of harder than only 3. However I'm not done yet with fonts so things will be different soon Smile
Cheers my friend.
Looks good!
Is it possible to keep the overlay as it was but change the colour to match the poster? So basically I stilk want to see the fan art slightly. Colour changing looks great if blur is on in home screen Smile
Hope you understand what I mean.. difficult to explain..
(2021-09-02, 16:18)Rijs43 Wrote: [ -> ]
Looks good!
I did it already on latest fix Confused
Hi Heppen could you implement a viewtype equal to widelist for episodes without plot only big poster and if possible enlarge episode titles or change color they look gray and not white. Thank you for the skin I hope to understand with the translator
(2021-09-02, 16:43)AudigierSanchez Wrote: [ -> ]Hi Heppen could you implement a viewtype equal to widelist for episodes without plot only big poster and if possible enlarge episode titles or change color they look gray and not white. Thank you for the skin I hope to understand with the translator
Hey!
I will definitely think of it when adding new views. I'm planning add some new view types as well as removing the "legacy" one from Estuary.
(2021-09-02, 16:20)nfm886 Wrote: [ -> ]
(2021-09-02, 16:02)nfm886 Wrote: [ -> ]Ok, I fixed it a little bit. Please re-download zip and do some more tests Wink
Looks good!
Thanks. Which setting did you use? My fanart on home is changing the colour however looks bright and want to have it as the original overlay with 15%. I am not using the blur option..
Hope you can direct me to the correct settings.
(2021-09-02, 09:43)Rijs43 Wrote: [ -> ]
(2021-09-02, 09:31)kocurek7 Wrote: [ -> ]
(2021-09-02, 09:01)Rijs43 Wrote: [ -> ]Did you sign in on YouTube and did you enable MPEG-DASH in YT settings?
I enabled MPEG-DASH (4K videos work)... Ho do i sign in? Is not filling my API keys enough?
Go to YT and open the addon. There you see an option to Sign in.
OK. I was not signed in. I did a fresh install of KODI, added and configured Youtube addon, signed in to Youtube and all movie trailers work Smile
Time to install Cosmic skin now...
Thank you for your help
regards
kocurek7
(2021-09-02, 16:53)Rijs43 Wrote: [ -> ]
(2021-09-02, 16:18)Rijs43 Wrote: [ -> ]Looks good!
Are you using version from this commit: https://github.com/nfm886/skin.cosmic/co...14a52a3d31 ?
Then I changed behavior of this overlay.
About settings, keep Luminance low and balance between mid values with Saturation. I like something about L:25 and S:35
This is how it works on my setup: https://streamable.com/i5fkiv
(2021-09-02, 16:59)nfm886 Wrote: [ -> ]This is how it works on my setup: https://streamable.com/i5fkiv
That looks very nice!!
(2021-09-02, 16:20)nfm886 Wrote: [ -> ]I did it already on latest fix Confused
Thanks for the example and this is what I had also. Possible to have the vignet back on it (pattern 1) and change only this colour? I like the colour changing but I would suggest to have vignet as well (similar to previous versions).
(2021-09-02, 20:13)Rijs43 Wrote: [ -> ]
(2021-09-02, 16:53)Rijs43 Wrote: [ -> ]Thanks. Which setting did you use? My fanart on home is changing the colour however looks bright and want to have it as the original overlay with 15%. I am not using the blur option..
I will back to it tomorrow. I have to fix little bug with indicators I noticed after update Angry
(2021-09-02, 20:32)nfm886 Wrote: [ -> ]
(2021-09-02, 16:59)nfm886 Wrote: [ -> ]Are you using version from this commit: https://github.com/nfm886/skin.cosmic/co...14a52a3d31 ?
Do your thing first pal..
Friend,
What you did with new Flix view is amazing! Really like the selection box and how the row is presented from left to right edge of the screen!
I beg you to have this behaviour also for the home screen Big Grin
