(2021-09-02, 23:07)Rijs43 Wrote: [ -> ]Friend,
What you did with new Flix view is amazing! Really like the selection box and how the row is presented from left to right edge of the screen!
I beg you to have this behaviour also for the home screen
Currently working on implementation this scrolling to home screen. This is how it looks so far:
https://streamable.com/1teq1k
That looks really nice, very slick.
If you dont mind me asking, how do you the numbers of episodes to show on the widget posters?
(2021-09-03, 11:03)Robertsond1987 Wrote: [ -> ]That looks really nice, very slick.
Is it coming from TMDbHelper add-on. I did not do anything special.
Just make sure you have not disabled indicators in Skin settings > Library > Manage watched indicators
Should this work with streaming addons or will this only be available for content in a local library?
(2021-09-03, 11:26)Robertsond1987 Wrote: [ -> ]Should this work with streaming addons or will this only be available for content in a local library?
It's basically for local content but I noticed it works also with PlexKodiConnect for example so it depends.
I'm not sure why, maybe because I'm using latest version of TMDbH but those indicators for episodes are shown also for remote content. I mean, I don't have that all episodes in my local library, but indicators shows them ^^
(2021-09-03, 10:48)nfm886 Wrote: [ -> ] (2021-09-02, 23:07)Rijs43 Wrote: [ -> ]Friend,
Currently working on implementation this scrolling to home screen. This is how it looks so far: https://streamable.com/1teq1k
So far.. LOL. This is already great! Cannot wait to test.
(2021-09-03, 11:31)nfm886 Wrote: [ -> ] (2021-09-03, 11:26)Robertsond1987 Wrote: [ -> ]Should this work with streaming addons or will this only be available for content in a local library?
This works for any thing you have scraped into your local library. For TV Shows it is showing the unwatched episodes, however this does not mean you have this also into your local library, unless you go to the axtual epiaode it self were you can see the local library indicator. I prefer to see the local library indicator for TV Shows level instead of episodes and similar to Movies.
[/quote]
[/quote]
Ah right, ok. Thanks for the info 👍
(2021-09-03, 12:41)Rijs43 Wrote: [ -> ] (2021-09-03, 10:48)nfm886 Wrote: [ -> ] (2021-09-02, 23:07)Rijs43 Wrote: [ -> ]Friend,
Thanks! Please download this zip file:
https://github.com/nfm886/skin.cosmic/ar...master.zip and test it
With all the updated masterzip files that are posted do i need to uninstall the current version of the skin first or can I just download then install the latest?
(2021-09-03, 17:00)roysmith Wrote: [ -> ]With all the updated masterzip files that are posted do i need to uninstall the current version of the skin first or can I just download then install the latest?
Just download and install it from zip. It will update the skin. If you want back to regular with automatic updates, just install again from repository.
(2021-09-02, 20:13)Rijs43 Wrote: [ -> ] (2021-09-02, 16:59)nfm886 Wrote: [ -> ] (2021-09-02, 16:53)Rijs43 Wrote: [ -> ]Thanks. Which setting did you use? My fanart on home is changing the colour however looks bright and want to have it as the original overlay with 15%. I am not using the blur option..
Hope you can direct me to the correct settings.
Are you using version from this commit: https://github.com/nfm886/skin.cosmic/co...14a52a3d31 ?
Then I changed behavior of this overlay.
About settings, keep Luminance low and balance between mid values with Saturation. I like something about L:25 and S:35
This is how it works on my setup: https://streamable.com/i5fkiv
Thanks for the example and this is what I had also. Possible to have the vignet back on it (pattern 1) and change only this colour? I like the colour changing but I would suggest to have vignet as well (similar to previous versions).
I made a change. Now patterns changing colours instead of full overlay, take a look:
https://streamable.com/tmb3g3
Also, there will be a background under the main menu when Flixed scrolling is enabled which will change colour as well.
(2021-09-03, 18:51)nfm886 Wrote: [ -> ] (2021-09-02, 20:13)Rijs43 Wrote: [ -> ] (2021-09-02, 16:59)nfm886 Wrote: [ -> ]Are you using version from this commit: https://github.com/nfm886/skin.cosmic/co...14a52a3d31 ?
I made a change. Now patterns changing colours instead of full overlay, take a look: https://streamable.com/tmb3g3
This is absolutely what they call beauty!
Will test your zip later in the evening.
Do you have this as a ZIP which also includes the Flix scrolling on home screen? I can than test both functionalities
Much appreciated!
(2021-09-03, 19:00)Rijs43 Wrote: [ -> ] (2021-09-03, 18:51)nfm886 Wrote: [ -> ] (2021-09-02, 20:13)Rijs43 Wrote: [ -> ]Thanks for the example and this is what I had also. Possible to have the vignet back on it (pattern 1) and change only this colour? I like the colour changing but I would suggest to have vignet as well (similar to previous versions).
Much appreciated!
Yeah, latest master branch includes all the changes, so basically you can download zip I gave you before.
