Full Version: Cosmic
Can't find it but is there an option to turn off logos?
The inconsistent standard in logo proportions means that vertically aligned logos bleeds into the plot in flix view and home menu.  I'm happy to live without them so the aesthetic is consistent.
(2021-09-03, 21:06)luckylukz Wrote: [ -> ]Was wondering what this was?
Added: Option to show EPG Event Icon on home screen
I've turned it one but not sure what it does or where it is. Is there an example of this?
Looking forward to more improvements on the Live TV section. Integration of channel logos on the guide would be excellent.
It's this icon in right corner under the clock: Image
It's visible in PVR widgets.
(2021-09-04, 03:47)neunghaha28 Wrote: [ -> ]I have a problem, some poster view type wall is missing.
I want the poster to show like this view which is perfect.
Please help me thanks bro.
I changed order of view types. Maybe this is your issue.
Just trigger hidden menu, and re-select view type to your wish.
Also you can lock view to make sure it won't change.
(2021-09-04, 05:21)Kokonutcreme Wrote: [ -> ]Can't find it but is there an option to turn off logos?
I will add this option today. I tho people prefer to see clearlogo so it's enabled by default. However an option to disable it will be nice.
It will be available in the evening with the next update.
(2021-09-04, 09:34)nfm886 Wrote: [ -> ]
Poster view type wall image size is distorted.
You will see the top of the image is missing.
I want it to show the correct image size.
(2021-09-04, 11:30)neunghaha28 Wrote: [ -> ]
Oh, ok. I see the issue.
It should be fixed now: https://imgur.com/843ufSF
(2021-09-04, 12:46)nfm886 Wrote: [ -> ]
(2021-09-04, 09:34)nfm886 Wrote: [ -> ]I changed order of view types. Maybe this is your issue.
Thanks for the quick help brother. Now everything looks great.
I love skin comsmic.
My watched indicators are gone on the home screen, they only come visible when i hover on the movie or serie.
before, i did see al my indicators without hovering over them.
for the rest the skin looks very good and real snappy, congrats on this wip!
Ive input my fanart.tv api key into an addon that i use for title and poster fanart. It works great on the fireTV setup using this skin, when ive entered in on my shield using this skin, the fanart isn't showing. I done the fireTV before the skin updated to the new side menu. Is their any reason why it wouldnt work on this latest update? Or could their be any skin setting ive selected thats causing it not to work?
(2021-09-04, 14:34)darkmen Wrote: [ -> ]My watched indicators are gone on the home screen, they only come visible when i hover on the movie or serie.
Probably you are using Flixed scrolling, right?
(2021-09-04, 16:05)Robertsond1987 Wrote: [ -> ]Ive input my fanart.tv api key into an addon that i use for title and poster fanart. It works great on the fireTV setup using this skin, when ive entered in on my shield using this skin, the fanart isn't showing. I done the fireTV before the skin updated to the new side menu. Is their any reason why it wouldnt work on this latest update? Or could their be any skin setting ive selected thats causing it not to work?
Do you have enabled this options?
"Enable colored background"
"Match overlay colour from image"?
(2021-09-04, 16:29)nfm886 Wrote: [ -> ]
No i dont have them enabled.......
EDIT- i have it working now. I changed all my setting in the skin and then changed them back, force closed and cleared cache and its now working.
(2021-09-04, 16:44)Robertsond1987 Wrote: [ -> ]
Uff. Glad it's working now. I'm curious what was the problem, hmm...
(2021-09-04, 16:25)nfm886 Wrote: [ -> ]
yes indeed.
