2021-09-07, 12:44
I installed your repo via "install from zip" but it doesn't work when I go to addons Heppen repo, its inaccessible. (using Leia Pi4)
(2021-09-07, 12:44)DarkEther Wrote: [ -> ](using Leia Pi4)
(2021-09-07, 09:24)nfm886 Wrote: [ -> ](2021-09-07, 03:35)M_rota Wrote: [ -> ]@nfm886 could you consider adding a option to select audio and subtitle before starting a movie?
Thank You
How it should works?
(2021-09-07, 14:12)M_rota Wrote: [ -> ]I have basically PKC, Netflix, TMDbH, Embuary, YouTube. NO conflicts here and everything is working for me.(2021-09-07, 09:27)nfm886 Wrote: [ -> ](2021-09-06, 20:39)M_rota Wrote: [ -> ]With plexkodiconnect backgroud trailer always start in full screen.
I'm using PKC too and everything seems to works as expected. I guess some add-ons or settings is conflicting.
What add-ons i need beside YouTube?
(2021-09-07, 14:16)M_rota Wrote: [ -> ]If it's possible I will probably add this Thanks(2021-09-07, 09:24)nfm886 Wrote: [ -> ](2021-09-07, 03:35)M_rota Wrote: [ -> ]@nfm886 could you consider adding a option to select audio and subtitle before starting a movie?
Thank You
Like netflix in your flix spotlight ex add a line under play for audio & subtitles we can choose if the movies or tv series have more than one language or more than one codec for the same language same for subtitle.
(2021-09-07, 09:17)nfm886 Wrote: [ -> ](2021-09-07, 03:57)magnetic Wrote: [ -> ]I wanted to know how can I see the quality of the stream. I would like to know at times if what I am watching if it’s 1080 or 720p especially when watching other things.You can see it by opening playerprocessinfo or by going to settings in OSD.
(2021-09-07, 18:25)Swanemar Wrote: [ -> ]Hey just a heads up. Watched indicators does not show until you highlight a movie/show (in poster view and widget on homescreen)
(2021-09-07, 18:25)Swanemar Wrote: [ -> ]Also; am I dumb or what does the Flix Spotlight do? Saw it was added but cannot see what it does.
(2021-09-07, 18:25)Swanemar Wrote: [ -> ]Awesome skin though!
(2021-09-07, 20:45)M_rota Wrote: [ -> ]Nothing special, seriously. I just installed PKC, added my server and went through first setup wizard, after kodi restart I logged in my account and boom, it works^^(2021-09-07, 09:27)nfm886 Wrote: [ -> ](2021-09-06, 20:39)M_rota Wrote: [ -> ]With plexkodiconnect backgroud trailer always start in full screen.
What are your settings to get it work ?
I have played with settings in YouTube add-ons and pkc and it always play in full screen when i hovering over a movie poster.
Thank You
(2021-09-07, 20:45)M_rota Wrote: [ -> ](2021-09-07, 09:27)nfm886 Wrote: [ -> ](2021-09-06, 20:39)M_rota Wrote: [ -> ]With plexkodiconnect backgroud trailer always start in full screen.
Thank You
(2021-09-07, 12:15)nfm886 Wrote: [ -> ](2021-09-07, 11:50)Rijs43 Wrote: [ -> ]Hi pal,I must think of it because it does not look well.
I believe someone else also asked for but not sure any more.
If Flix scrolling is enabled, can we have an option to display all indicators on the posters instead of only the highlited poster?
(2021-09-07, 21:39)Rijs43 Wrote: [ -> ](2021-09-07, 20:45)M_rota Wrote: [ -> ](2021-09-07, 09:27)nfm886 Wrote: [ -> ]I'm using PKC too and everything seems to works as expected. I guess some add-ons or settings is conflicting.
Thank You
How do you trigger the trailers to work? Is this through the spot light function? Are you highliting a poster in a widget and press ok to play? Perhaps a screen record would help to identify..
