Full Version: Cosmic
Please add a indicator (arrow, numbers, ...) to show, that there are other widgets below or above.
Thx
(2021-07-31, 09:47)Aaiemron Wrote: [ -> ]A little question: Does this skin get an autoclose OSD option?
Not yet, but I will implement this Smile
btw. Just made some changes to EPG + scrolling animation. Actually this is scrolling on Xiaomi Mi Box S: https://streamable.com/c0rnxh
Few changes to blur look and feel: https://streamable.com/fsysq1
Just added little overlay on Home, so blur is more dimmed.
Also disabled vignette in DialogVideoInfo, so there is fullscreen fanart.
Time for Widgets aspect ratio. Just started with Landscape: https://streamable.com/z3enkg
If you have any proposition, please show me an example screenshot :
Looking at that video , just my opinion of course , the fanart in the flix view would look better moved further to the right ( am assuming fanart isn't set to "fullscreen" in flix view )  and the vignette extended further to the right so that the info text has the vignette as background and doesn't sit in front of fanart ?
(2021-07-31, 13:22)ontap Wrote: [ -> ]the fanart in the flix view would look better moved further to the right ( am assuming fanart isn't set to "fullscreen" in flix view )  and the vignette extended further to the right so that the info text has the vignette as background and doesn't sit in front of fanart ?
To be honest, it's hard to play with... I will definitely try to improve this.
(2021-07-31, 13:27)nfm886 Wrote: [ -> ]
I have done same in a couple of skins  , changed fanart from full screen in the set view and sized to fit top right so you get most of it shown rather than just top 1/3 , tx for considering it , its not a deal breaker though.
(2021-07-31, 13:18)nfm886 Wrote: [ -> ]Time for Widgets aspect ratio. Just started with Landscape: https://streamable.com/z3enkg
Another great look!
Is it possible to add shadows to posters/ Landscape so they are more 'floating on the screen?
(2021-07-31, 15:07)Rijs43 Wrote: [ -> ]Is it possible to add shadows to posters/ Landscape so they are more 'floating on the screen?
Just like this: https://imgur.com/VFhOLmR ? Wink
(2021-07-31, 17:27)nfm886 Wrote: [ -> ]
Yes! Great clean look pal!!
(2021-07-30, 18:27)nfm886 Wrote: [ -> ]
(2021-07-30, 18:21)trkselim Wrote: [ -> ]
(2021-07-30, 18:11)nfm886 Wrote: [ -> ]Do you mean that title near the widget name? Maybe as an option Smile
No i mean the view
Ah ok Smile
Then yes, I'm planning to add some other views, maybe one of them similar to this one you showed Smile
P.S. Just added Blur option, short presentation: https://streamable.com/8wea0o Big Grin
Everything loads so fast!! Is it possible for you to have the genre as you scroll through movies? Like how the ratings show?
Looks awesome
Can this be downloaded yet?
I dont see it in the happen's repository.
Edit:
Just read the first post. I see it's not available, I just assumed it was with the suggestions people were giving. Didn't realize it was going off the pics.
Keep up the great work!
Is this a blurred image? What are you using?
(2021-08-01, 06:14)Edworld Wrote: [ -> ]
Do you mean background? Then yes, it's blurred image. I'm using TMDb Helper to achieve this blur.
(2021-08-01, 07:33)nfm886 Wrote: [ -> ]
(2021-07-31, 17:27)nfm886 Wrote: [ -> ]Just like this: https://imgur.com/VFhOLmR ? Wink
Did you use fanart or ?
