(2021-09-19, 15:29)Rijs43 Wrote: [ -> ]Hi pal,
Is it possible to disable the trailer function per widget? I have a widget for In Progress and no need to see the trailer before starting watching. I have to wait until trailer starts to activate the Play button
Hey,
I think I found a solution for this freeze after opening Flix Spotlight when trailer is loading. Would you like to test it? Please download this zip file:
https://github.com/nfm886/skin.cosmic/ar...master.zip
(2021-09-23, 13:11)nfm886 Wrote: [ -> ] (2021-09-19, 15:29)Rijs43 Wrote: [ -> ]Hi pal,
Hey,
I think I found a solution for this freeze after opening Flix Spotlight when trailer is loading. Would you like to test it? Please download this zip file: https://github.com/nfm886/skin.cosmic/ar...master.zip
Hi pal, I have tested and provided feedback in Github. Works great, however when lever I press play before trailer starts and brings me to next screen the trailer suddenly starts in the background. Possible to disable trailer once you hit the play button?
Thanks for the solution. Much appreciated.
(2021-09-22, 22:56)Rijs43 Wrote: [ -> ] (2021-09-22, 21:22)sunlollyking Wrote: [ -> ]Hey does anyone know how i can ungrey out all of the menu options around trailers? I've followed the video guide but i can't seem to get any auto trailer functionality added at all with all the menu options just greyed out.
Do you have youtube installed?
I have all of the dependencies installed but i don't have the device with me currently to see if it is explicitly installed secondary to Cosmic.
(2021-09-23, 15:48)sunlollyking Wrote: [ -> ] (2021-09-22, 22:56)Rijs43 Wrote: [ -> ] (2021-09-22, 21:22)sunlollyking Wrote: [ -> ]Hey does anyone know how i can ungrey out all of the menu options around trailers? I've followed the video guide but i can't seem to get any auto trailer functionality added at all with all the menu options just greyed out.
Youtube is not a dependency of Cosmic skin. You need to install separately and add in API in YT settings. Once you install YT the settings in skin can be switched off and on.
Hello.
Just switched my system to an odroid N2+ with coreelec. I've added your repo but when I try to go into it it says I can't connect. Do you have any idea why this might be?
I've got the skin installed and running on my PC so it's very strange
(2021-09-24, 18:23)powerlessbutton Wrote: [ -> ]Hello.
Please check for updates before accessing my repo. Maybe it will help
I assume you are using CE with Kodi19+ right?
(2021-09-24, 18:48)nfm886 Wrote: [ -> ] (2021-09-24, 18:23)powerlessbutton Wrote: [ -> ]Hello.
Please check for updates before accessing my repo. Maybe it will help I assume you are using CE with Kodi19+ right?
I am indeed. Just checked for updates and it says there aren't any. Still saying could not connect also 😭
(2021-09-24, 18:51)powerlessbutton Wrote: [ -> ] (2021-09-24, 18:48)nfm886 Wrote: [ -> ] (2021-09-24, 18:23)powerlessbutton Wrote: [ -> ]Hello.
Please attach a log file after this message pop up. It will help to investigate the issue. It can be cut off to last few lines where error occurred not full log file. Upload it to paste.kodi.tv
(2021-09-24, 19:10)nfm886 Wrote: [ -> ] (2021-09-24, 18:51)powerlessbutton Wrote: [ -> ] (2021-09-24, 18:48)nfm886 Wrote: [ -> ]Please check for updates before accessing my repo. Maybe it will help I assume you are using CE with Kodi19+ right?
https://paste.kodi.tv/topumesuto.kodi
I'm not sure if this is the right one. Hopefully it is
(2021-09-24, 19:34)powerlessbutton Wrote: [ -> ] (2021-09-24, 19:10)nfm886 Wrote: [ -> ] (2021-09-24, 18:51)powerlessbutton Wrote: [ -> ]I am indeed. Just checked for updates and it says there aren't any. Still saying could not connect also 😭
https://paste.kodi.tv/baninuxime.kodi
This one might be better for you
You are using
CoreELEC (official): 9.2.8 which is 18.9. That's why it is not working for you
Please update CE to 19.2 at least. You may look also at this topic:
https://discourse.coreelec.org/t/coreele...ment/16684
(2021-09-24, 19:40)nfm886 Wrote: [ -> ] (2021-09-24, 19:34)powerlessbutton Wrote: [ -> ] (2021-09-24, 19:10)nfm886 Wrote: [ -> ]Please attach a log file after this message pop up. It will help to investigate the issue. It can be cut off to last few lines where error occurred not full log file. Upload it to paste.kodi.tv
You are using CoreELEC (official): 9.2.8 which is 18.9. That's why it is not working for you
Please update CE to 19.2 at least. You may look also at this topic: https://discourse.coreelec.org/t/coreele...ment/16684
oh gosh, dont i look silly, i thought that was the latest one. Many apologies, and thank you for noticing!
Hello.
Any improvements on the classic layout already?
What I mean is rhe color of the menubar if using Flix Spotlight.
I like it transparent just like the non classic layout
Sorry for asking again
(2021-09-24, 20:07)Aaiemron Wrote: [ -> ]Hello.
Yes. But I don't know when it's happen. I'm kind of busy lately. Don't have that many time to work with Cosmic.
There is still a lot of aspects to improve, not only classic layout. There should be few more view types for library, a lot of bugs are reported on GitHub.
(2021-09-24, 20:31)nfm886 Wrote: [ -> ] (2021-09-24, 20:07)Aaiemron Wrote: [ -> ]Hello.
Oke, I understand. No worries. Thanks for answering.
