Full Version: Cosmic
(2021-09-24, 20:07)Aaiemron Wrote: [ -> ]Hello.
Any improvements on the classic layout already?
What I mean is rhe color of the menubar if using Flix Spotlight.
I like it transparent just like the non classic layout
Sorry for asking again
Hey - commit: https://github.com/nfm886/skin.cosmic/co...074457b747
Removed until I find an idea how to change this layout.
(2021-09-28, 11:45)nfm886 Wrote: [ -> ]
Thanks. I will test this tonight when I'm home
(2021-09-28, 12:44)Aaiemron Wrote: [ -> ]
To be honest, I'm not happy with current state of Classic layout but don't have better idea how to improve it. Maybe soon I will find an inspiration Smile
(2021-09-28, 13:02)nfm886 Wrote: [ -> ]
(2021-09-28, 11:45)nfm886 Wrote: [ -> ]Hey - commit: https://github.com/nfm886/skin.cosmic/co...074457b747
A suggestion...
https://i.postimg.cc/g0VjSrLk/cosmic.png
(2021-09-28, 14:33)chitridang Wrote: [ -> ]
(2021-09-28, 12:44)Aaiemron Wrote: [ -> ]Thanks. I will test this tonight when I'm home
A suggestion...
Thanks. I will totally rewrite Classic layout the same as I'm doing with Horizontal right now. Horizontal will have totally new look and Classic too soon Wink
Currently working on new look for horizontal layout as I was not satisfied with previous look. This is how it looks right now: https://streamable.com/e67gmr
Also planning to implement background trailers and Flix spotlight to this layout Smile
Well, I just tested it and it's more than oke for me. I like it the way it is right now.
So thank you.
(2021-09-28, 16:32)nfm886 Wrote: [ -> ]Currently working on new look for horizontal layout as I was not satisfied with previous look. This is how it looks right now: https://streamable.com/e67gmr
How do you get the posters along the bottom in your example?
Really like the buttons, Play, Trailer, More Info being visible all the time Big Grin hope you will bring this to other views as well. Looking forward to new changes Smile
Looks great but please give option to have the menu bar at the bottom as well Wink
(2021-09-28, 22:27)pusb87 Wrote: [ -> ]
Unfortunately I won't add this option. There is no much place for it.
Also I forgot about main goal behind this skin which is being simple and lightweight.
This skin is growing and being too big. I must slim down it.
In the next few days I'm planning to clean it a little bit. And fix some bugs. But first I wanna finish this layout.
(2021-09-29, 12:12)nfm886 Wrote: [ -> ]
Soory , dont quite understand what you mean by no much place Huh
if you were meaning to say not much space then i cant see how it would differ  by having it at the bottom rather than the top ?
(2021-09-29, 18:02)pusb87 Wrote: [ -> ]
(2021-09-28, 22:27)pusb87 Wrote: [ -> ]Looks great but please give option to have the menu bar at the bottom as well Wink
Yes, I meant space. If you want menu on the bottom then make a fork Wink
For me it won't looks good since widgets with this "blurred" background will be above the menu. Sorry, I won't do it.
Just an idea but both on the horizontal or the classic vertical it would be great to have an option to display more than one widget row at the same time instead of the plot and rating.
A bit like it was on ressurection, and then show the info (plot, rating, clearlogo) on click as it is now would make it even better.
(2021-09-30, 00:44)Kkamer Wrote: [ -> ]Just an idea but both on the horizontal or the classic vertical it would be great to have an option to display more than one widget row at the same time instead of the plot and rating.
Someone mentioned it before on GitHub. It's something I want to add but it is not that easy to implement so it's a bit far on my ToDo list Smile
