Full Version: Cosmic
(2021-08-01, 14:42)Edworld Wrote: [ -> ]
(2021-08-01, 07:33)nfm886 Wrote: [ -> ]
(2021-08-01, 06:14)Edworld Wrote: [ -> ]Is this a blurred image? What are you using?
Do you mean background? Then yes, it's blurred image. I'm using TMDb Helper to achieve this blur.
Did you use fanart or ?
Yes, fanart.
I saw a post about you doing a horizontal layout, there's a skin(GTV) that was never finished that had a great horizontal implementation, it's just a suggestion but the highlight color on the home menu on widgets (special the landscape) looks awesome and there's no other skin with it. I tried to mod your AZ2 resurrection to get something close but never managed to make it look as good only changed colors and landscape sizes. Maybe you can look at it and make something even better if you also like it.
Congratulations for all the hard work so far.
(2021-08-01, 18:54)Kkamer Wrote: [ -> ]I saw a post about you doing a horizontal layout, there's a skin(GTV) that was never finished that had a great horizontal implementation, it's just a suggestion but the highlight color on the home menu on widgets (special the landscape) looks awesome and there's no other skin with it. I tried to mod your AZ2 resurrection to get something close but never managed to make it look as good only changed colors and landscape sizes. Maybe you can look at it and make something even better if you also like it.
Thanks for your suggestion. I will look at it Smile
Meanwhile, added new layout for library view: https://streamable.com/cj7h59
(2021-08-01, 18:56)nfm886 Wrote: [ -> ]
I see a square icon on right upper corner of posters when you scroll.. what is this for? To indicate available on local library?
(2021-08-01, 19:56)Rijs43 Wrote: [ -> ]
It's indicate whether you already watched a movie or no Smile
(2021-08-01, 20:10)nfm886 Wrote: [ -> ]
(2021-08-01, 18:56)nfm886 Wrote: [ -> ]Thanks for your suggestion. I will look at it Smile
Ah ok, thanks. Hope you can implement local file indication as well Smile
Great progress made already!
Really like that new view.
Skin is looking clean!
Could you add an option to show clear logo on osd as well as clear art?
(2021-08-02, 00:04)CollotsSpot Wrote: [ -> ]Skin is looking clean!
Just added clearlogo: https://imgur.com/kmaHadN
Currently testing new fanart positioning under the viniette and I must say, it looks much better: https://streamable.com/ey58kp Smile
(2021-08-02, 17:13)nfm886 Wrote: [ -> ]Currently testing new fanart positioning under the viniette and I must say, it looks much better: https://streamable.com/ey58kp Smile
Wow, this is amazing
How about live TV channel list? Can you share a sneak peek?
(2021-08-02, 21:14)makakam Wrote: [ -> ]How about live TV channel list? Can you share a sneak peek?
Not much changes made yet but I think I won't touch it too much because if something is good, why changing it Smile
https://streamable.com/4gn7m8
That's exactly what I thought Smile
Looking great, keep up the good job Smile
I'm working on Horizontal layout, you can see what I have done so far...
