Full Version: Cosmic
(2021-10-21, 19:00)nfm886 Wrote: [ -> ]
(2021-10-21, 18:54)chewiiie Wrote: [ -> ]Hello,
Just installed the skin. I'm struggling with the background on the home/start page. For some reason, my background is only visible in the top right quarter of the screen. The left and bottom of the screen is completely black, whatever the background is. Tried a lot of options, even reset the skin options to default. Can't get the background fully displayed on the main menu like on the video/tutorial.
Any idea?
Hi Smile
I changed the look of the classic layout. That's why background is now not full screen Wink
Ah. Too bad we don't have a choice. I've enabled widgets for most entries of the main menu so the black portions of the screen are now populated. And removed the global background since it is hidden anyway. It is less weird now.
I would just have liked to have no widgets on the main menu like on the beginning of your video with full background behind the menu (not blacked out).
(2021-10-21, 19:30)chewiiie Wrote: [ -> ]
Any idea?
Hi Smile
I will consider adding option to hide those bars and resize background fanart to be on fullscreen but currently I'm enjoying free time Smile
(2021-10-21, 20:44)nfm886 Wrote: [ -> ]
(2021-10-21, 19:00)nfm886 Wrote: [ -> ]Hi Smile
Thanks! Enjoy
(2021-10-03, 21:18)kokoplex Wrote: [ -> ]Thank you heppen for this amazing skin !
Just some ideas and difficulties to purpose
In vertical layout, it's possible to match overlay colour with color of fanart background ?
Actually it's only dark color for any entries.
By the way, could you add a rotated fanart background for x seconds ?
How can i activate the rounded poster on widget ? I didn't find the option.
Could you add a feature to scroll down from widgets to widgets for any menus.
Actually we have to go back on left section to display widgets of each category (hope i'm clear enough)
Into widget, could you add a possiblity to swith automatically movie 1 to movie 2 to movie 3, etc... for x seconds ?
Hi @nfm886
Did you consider some ideas for future or it's not in your plan ?
Hola, es posible intalar cosmic en kodi leia?
(2021-10-31, 13:42)neneique Wrote: [ -> ]Hola, es posible intalar cosmic en kodi leia?
We are an English forum, please also post an English translation.
But it looks like this skin is for v19-Matrix or higher.
I've just set up the skin and playing around with it. Currently, if I'm scrolling through a widget and want to return sidebar/main menu....the only way to do it is to scroll all the way back to the beginning of the widget. Pressing the back or home key does nothing.
Am I missing something obvious?
(2021-11-03, 03:08)mahican Wrote: [ -> ]I've just set up the skin and playing around with it. Currently, if I'm scrolling through a widget and want to return sidebar/main menu....the only way to do it is to scroll all the way back to the beginning of the widget. Pressing the back or home key does nothing.
No your not missing something.
This is a feature that has been requested.
This skin is still fairly new and I'm sure the dev will get to it in good time.
He's currently taking a break and will be back.
(2021-11-04, 11:14)Robertsond1987 Wrote: [ -> ]This skin is still fairly new and I'm sure the dev will get to it in good time.
Yes. Thanks for patient Smile
Use Resurrection. It's similar & looks finished.
Hi Folks,
I am quite impressed with this new cosmic skin and how professional and classy it looks.
I have set up the skin and pretty much everything works really well.  However, I have run into one issue getting the TMDB Helper to play videos that has stumped me and I hope someone here on this thread will be able to point me in the right direction to resolve it.
I am using Kodi 19.3, Cosmic 1.59 and TMDB Helper 4.4.18 but unable to update the players using the tmdbplayers URL.  Below is a snippet with the section from the logs containing the errors. The full set of logs can be found here: https://paste.kodi.tv/ofififosaj.
---- ERROR SECTION BEGINS HERE -------
021-11-08 20:08:38.888 T:22246 INFO <general>: [plugin.video.themoviedb.helper] URL check passed for http://bit.ly/tmdbplayers: Status code [200] 2021-11-08 20:08:38.992 T:22246 ERROR <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <class 'requests.exceptions.ConnectionError'> Error Contents: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer')) Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.urllib3/lib/urllib3/connectionpool.py", line 699, in urlopen httplib_response = self._make_request( File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.urllib3/lib/urllib3/connectionpool.py", line 445, in _make_request six.raise_from(e, None) File "<string>", line 3, in raise_from File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.urllib3/lib/urllib3/connectionpool.py", line 440, in _make_request httplib_response = conn.getresponse() File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 1347, in getresponse response.begin() File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 307, in begin version, status, reason = self._read_status() File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 268, in _read_status line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1") File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/socket.py", line 669, in readinto return self._sock.recv_into(b) ConnectionResetError: [Errno 104] Connection reset by peer During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/adapters.py", line 439, in send resp = conn.urlopen( File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.urllib3/lib/urllib3/connectionpool.py", line 755, in urlopen retries = retries.increment( File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.urllib3/lib/urllib3/util/retry.py", line 532, in increment raise six.reraise(type(error), error, _stacktrace) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.urllib3/lib/urllib3/packages/six.py", line 734, in reraise raise value.with_traceback(tb) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.urllib3/lib/urllib3/connectionpool.py", line 699, in urlopen httplib_response = self._make_request( File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.urllib3/lib/urllib3/connectionpool.py", line 445, in _make_request six.raise_from(e, None) File "<string>", line 3, in raise_from File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.urllib3/lib/urllib3/connectionpool.py", line 440, in _make_request httplib_response = conn.getresponse() File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 1347, in getresponse response.begin() File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 307, in begin version, status, reason = self._read_status() File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/http/client.py", line 268, in _read_status line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1") File "/data/user/0/org.xbmc.kodi/cache/apk/assets/python3.8/lib/python3.8/socket.py", line 669, in readinto return self._sock.recv_into(b) urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer')) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.themoviedb.helper/script.py", line 7, in <module> Script().router() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.themoviedb.helper/resources/lib/script/router.py", line 414, in router return self.routing_table[route_taken](**self.params) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.themoviedb.helper/resources/lib/script/router.py", line 382, in <lambda> 'update_players': lambda **kwargs: update_players(), File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.themoviedb.helper/resources/lib/script/router.py", line 206, in update_players downloader.get_extracted_zip() File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.themoviedb.helper/resources/lib/files/downloader.py", line 129, in get_extracted_zip response = self.open_url(self.download_url) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.themoviedb.helper/resources/lib/files/downloader.py", line 20, in wrapper return func(*args, **kwargs) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.themoviedb.helper/resources/lib/files/downloader.py", line 89, in open_url response = requests.get(url, timeout=10.000, stream=stream, auth=cred) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/api.py", line 76, in get return request('get', url, params=params, **kwargs) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/api.py", line 61, in request return session.request(method=method, url=url, **kwargs) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 542, in request resp = self.send(prep, **send_kwargs) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 655, in send r = adapter.send(request, **kwargs) File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/adapters.py", line 498, in send raise ConnectionError(err, request=request) requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer')) -->End of Python script error report<--
------ END OF ERROR SECTION   ------
I mainly use Kodi for live tv and I’m loving the polished look of this skin except for 2 components that I always see.
Here are my issues:
The information on the channel while watching looks a bit messy with the alignment on the left side. The spacing and alignment looks random and the information is confusing. I wish it looked more unified
https://ibb.co/m8Ch55T
Also when switching channels, the slash in the overlay looks a bit less polished with it striking directly through the time. I also hope there’s a cleaner option instead of the glowing slash which looks a bit too gimmicky for the over all polished look of the rest of the UI.
https://ibb.co/LJMjx1N
If there are options to customise these already, I would kindly like to know.
Thanks and awesome work!
It seems that @nfm886 is back Big Grin Big Grin Big Grin
(2021-11-09, 22:39)Chobie_ Wrote: [ -> ]The information on the channel while watching looks a bit messy with the alignment on the left side. The spacing and alignment looks random and the information is confusing. I wish it looked more unified
That's how I designed it and it is how it is Wink I won't change this OSD since I added new one: https://imgur.com/jI4JmJk
(2021-11-09, 22:39)Chobie_ Wrote: [ -> ]Also when switching channels, the slash in the overlay looks a bit less polished with it striking directly through the time. I also hope there’s a cleaner option instead of the glowing slash which looks a bit too gimmicky for the over all polished look of the rest of the UI.
This OSD is to improve. I will try to do something with it since I'm not happy with it too. Hope to change it in next few days Smile
Also thanks for kind words. I appreciate every positive comments, love you guys Smile
(2021-11-10, 11:11)chitridang Wrote: [ -> ]It seems that @nfm886 is back Big Grin Big Grin Big Grin
Indeed! Smile Thank you for your patience and hello again Big Grin
