Full Version: Cosmic
(2021-11-10, 11:12)nfm886 Wrote: [ -> ]That's how I designed it and it is how it is Wink I won't change this OSD since I added new one: https://imgur.com/jI4JmJk
Such a nice OSD is also perfect for Movies and TV shows.
With underneath small OSD buttons.
(2021-11-10, 11:37)Aaiemron Wrote: [ -> ]
Yeah, maybe. However OSD will be stay the same for a while.
Hello.
I would like to say first that i love this skin.it works so much faster on my mi box s then any other i tried.it gives me a whole new expirience.
I have one feature request if you would like to consider adding.
It is about progres indicators in widgets.curently they only show once i higlight a movie. I would like them to show all the time.
I included picture for better understanding.
Movie dune shows as completed once i hower over it but when i move indicator it doesnt show anything
https://ibb.co/Nr2RHZH
https://ibb.co/ZxPR1gj
(2021-11-10, 12:09)slickw Wrote: [ -> ]Hello.
Ah yeah. First of all - thanks Smile
About indicators. It's a bug currently. Previous behaviour was to show them all. Now I broke something Rolleyes and they are shown only when you highlight an item. I hope to fix this soon but there is no ETA for it. I had a little break from the work and now it's hard to get back into it but I'm back... Wink
(2021-11-10, 11:45)nfm886 Wrote: [ -> ]Yeah, maybe. However OSD will be stay the same for a while.
Oke thank for the answer.
I like this skin a lot, the only thing I personally find a little less beautiful is the OSD because of the (in my opinion) too big OSD buttons.
Maybe as an option to make them a bit smaller? So we can choose?
Just a thought.
Glad you're back to develop this nice skin
(2021-11-10, 14:17)Aaiemron Wrote: [ -> ]Maybe as an option to make them a bit smaller? So we can choose?
I don't know, we will see. I like them ^^
Spróbuję zapytać ponownie.
Jak przywrócić poprzedni widok klasycznego menu bez tych srebrnych pasów z boku i u góry?
I try to ask once again. How to bring back previous look of classic home layout? Without silver bars.
(2021-11-10, 12:28)nfm886 Wrote: [ -> ]
Awesome,take your time its not that big of a deal anyways 🙂
I have one more question.
After watching a movie or tv show all my widgets on homescreen get refreshed. And that can take alot of time on my mi box .
I understand its a feature and it makes alot of sense when i use skin on PC, but can you maybe tell me a way to disable widget refresh ? Some file i can edit and change a few lines maybe ?
(2021-11-11, 12:17)slickw Wrote: [ -> ]I understand its a feature and it makes alot of sense when i use skin on PC, but can you maybe tell me a way to disable widget refresh ? Some file i can edit and change a few lines maybe ?
It's managed by Kodi itself. Skin has nothing to do with it.
(2021-11-10, 23:29)kodishu Wrote: [ -> ]I try to ask once again. How to bring back previous look of classic home layout? Without silver bars.
It's impossible right now but I think I will add this option someday since many people was asking for it before...
(2021-11-11, 15:53)nfm886 Wrote: [ -> ]
Yes i did some research and you are right of course 🙂, but for some reason it didnt refresh as much with artic horizon.doesnt matter.
On the other hand i did some digging on your github to help you with my first issue with watch indicators not working corectly.
I found the commit that brought the problem
https://github.com/nfm886/skin.cosmic/co...cac97ea72b
In xml/Includes_View.xml
If i just delete this line
241. <visible>$PARAM[visible]</visible>
Indicators work correctly again
I hope i helped you.
Thanks again for great skin 😊
Is there any option to show video details (aspect ratio, codec, fps, audio streams, etc.) in the main movie page?
I can not find anything to have them enabled whilst they are available on other skins.
Details are instead properly shown when playing the video and pressing the "info" button.
Thanks in advance.
(2021-11-14, 01:30)slickw Wrote: [ -> ]Yes i did some research and you are right of course 🙂, but for some reason it didnt refresh as much with artic horizon.doesnt matter.
Are you sure? Is it not because AH does not indicate it is refreshing widgets? Tongue
(2021-11-14, 01:30)slickw Wrote: [ -> ]On the other hand i did some digging on your github to help you with my first issue with watch indicators not working corectly.
Oh well. I will take a closer look on it tomorrow. Thanks! Smile
Kodi 19.3 is freshly installed. how do i remove gray bar? Image
Today in the evening will be new update.
Just added option to disable those bars in Classic layout.
