2021-07-28, 12:38
Hello,
after installing 19.1 on my windows 10 I cannot browse sources (via smb in my case). I get the endless rotating cursor.
On my debug log I get these repeating entries:
hastebin - varisubamo (kodi.tv)
I use multipath and see above that it gets stuck on 192.168.178.30 (a NAS that is down) and seams to not be able to skip it.
In my advancedsettings.xml I have the following:
<network>
<curlclienttimeout>10</curlclienttimeout> <!-- Timeout in seconds for libcurl (http/ftp) connections -->
<curllowspeedtime>20</curllowspeedtime> <!-- Time in seconds for libcurl to consider a connection lowspeed -->
<curlretries>2</curlretries> <!-- Amount of retries for certain failed libcurl operations (e.g. timeout) -->
<httpproxyusername></httpproxyusername> <!-- username for Basic Proxy Authentication -->
<httpproxypassword></httpproxypassword> <!-- password for Basic Proxy Authentication -->
<disableipv6>true</disableipv6> <!-- Certain hardware/OS combinations have trouble with ipv6. Set "true" to disable -->
<disablehttp2>false</disablehttp2> <!-- Added in v19- Allows disabling HTTP2 for broken Curl / HTTP2 servers -->
<nfstimeout>5</nfstimeout> <!-- Added in v19- Timeout in seconds for NFS access, 0 = wait forever (previous behaviour) default is 5s -->
</network>
<samba>
<doscodepage></doscodepage> <!-- code page to use for filenames -->
<clienttimeout>2</clienttimeout> <!-- timeout (in seconds) -->
<statfiles>false</statfiles> <!-- Set to false to disable smb stat() on files to speed up listings of large directories (over slow links) -->
</samba>
Any help would be greatly appreciated.
Thank you,
Thanos
<network>
</network>
<samba>
</samba>
Thank you,
Thanos
