Full Version: Remove "Watched" from Recently Added
Is there a way to remove watched content from the Recently Added widget?
It'd be nice to clean that up.
(2021-08-02, 06:41)Litcube Wrote: [ -> ]Is there a way to remove watched content from the Recently Added widget?
@Litcube , please be more specific as to which recently added widget you are referring to.  Skin provided recently added movies, episodes? (by skin provided I mean the ones that you configure from Default Shelves).  If it is the skin provided ones, watched content is already removed once you watch an item.  Make sure that you have the following setting set to NO:
If that is set to no, then the Recently Added Movies, Recently Added Episodes, Recently Added Music Videos, Recently Played TV Shows and Recently Added Songs widgets will not show watched items.
However, if you are using a widget from an addon, then it is up to the addon and its settings to show watched items or not.  I cannot control that from the skin for addon widgets.
Regards,
Bart
That did it!
Thanks Bart!
