Full Version: Library Node Editor
Hello, I am having trouble with the library node editor. I have successfully created a node that will display all my 4K movies in a separate section up top, however I am having trouble doing this for TV shows. I tried to create a node the same way as the movies, but the rule for resolution does not exist when the content for the node is TV Shows. I have managed to create a rule (Path contains UHD) which seems to work. However I don't want to have to put that text in all relevant show folders so it can grab those. I would prefer if I could do the same thing as the movies, that way it is fully autonomous. I also saw that when content is changed to Episodes, the rule for resolution is available again. Why does it not exist when content chosen is TV shows? Any help would be greatly appreciated. Thanks.
