Full Version: Multiple Web Interfaces Behind Nginx Reverse proxy
Hello,
I have muliple intances of kodi running inside my house, i use the web interface to control them regularly.
I recently decided i wanted to run a small web server and reserse proxy to better orginize my different web interfaces and other portals.
I have tried to get even 1 kodi web interface working and i can not. I have every other portal now configured with nginx but kodi's web interface (and the reason i started) wont work. I am currently just trying to set up the first one, i call Kodi-alpha. id like to access it at mydomain.com/kodi-alpha/ but no matter what i do it just shows a blank white page with"file not found" kodi alpha is the localhost and is configured
my nginx proxy entery for the kodi-alpha looks like this
    location /kodi-alpha/ {
     proxy_set_header    Host $http_host;
    proxy_set_header    X-Real-IP $remote_addr;
    proxy_set_header    X-Scheme $scheme;
    proxy_pass          http://127.0.0.1:8080/;
    proxy_http_version  1.1;
    proxy_set_header    Upgrade $http_upgrade;
    proxy_set_header    Connection "upgrade";
and it loads up, and even prompts for password, but then goes to a white blank page that reads "File Not Found'
Id really like to figure this out as in the long run i want to have a few others set up,
mydomain.ca/kodi-alpha
mydomain.ca/kodi-beta
mydomain.ca/kodi-gamma
mydomain.ca/kodi-HomeTheater
mydomain.ca/kodi-Livingroom
but i need to figure out what i am doing wrong. currently alpha is the local host. the rest are on other computers but they all seem to be doing the same thing
The web interfaces uses a websocket connection for json rpc. You probably need to proxy that as well.
You can open developer tools in your browser to better observe(via network tab) what's going on.
(2021-08-17, 08:59)wsnipex Wrote: [ -> ]The web interfaces uses a websocket connection for json rpc. You probably need to proxy that as well.
After some fidling and googling i found a solution.
location /Kodi-Alpha/ {
                    proxy_pass          http://192.168.2.10:8080/;
                        location ~ ^/(image|jsonrpc) {
                            proxy_pass http://192.168.2.10:8080;
                            proxy_redirect off;
                            proxy_set_header Host 192.168.2.10:$server_port;
                            proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                            proxy_set_header X-Forwarded-Ssl off;
i had to hard code the host header in the jsonrcp to allow everthing to work, otherwise i was getting mixed interfaces between my installed but now it seems to work thanks for the help.
i regret to say that while it does seem to work every so often it often still shows mixed information on the interface. i recognise at that this might not be the right place but any help would be appreciated.
