I 've used keymap editor to edit gen.xml such that pressing "5" on the remote takes a screenshot.
I set it to do so both globally, within pictures, and within slideshow. This works without issue in general to use the "5" button to take a screenshot throughout my kodi setup.
However, if I press info during picture slideshow to show image name and date etc and then press "5" then no screenshot is taken.
Anybody have any idea how I can get it to take this screenshot while the picture info dialogue is displayed? I like to take a screenshot of that info so I know where to find the source image when looking at the screenshots at a later date.
Many thanks if anyone can help
(2021-08-21, 20:53)kiboy6 Wrote: [ -> ]I 've used keymap editor to edit gen.xml such that pressing "5" on the remote takes a screenshot.
It may or may not help, I use an app Lightshot (Windows or Mac)
(2021-08-31, 07:10)fsurfer Wrote: [ -> ] (2021-08-21, 20:53)kiboy6 Wrote: [ -> ]
Thanks so much - but I need to take the screenshot within Kodi (running on a Coreelec box). Kodi's inbuilt screenshot function works great - I just can't get it to take a screenshot of the picture info dialogue.
Just tested and it's working for me so we're going to need some more info.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Thanks so much for looking into this - sorry for late reply
here's the log
https://paste.kodi.tv/movozazejo.kodi
Here's what is happening as described in the log:
1.) I navigate to within kodi pictures to "IMG_9645.JPG" then select that image to display it fullscreen.
2.) With that image shown full screen i press my preassigned global screenshot remote key . This key is "5" on my remote control
3.) That screenshot is saved successfully (as "screenshot035.png") in the screenshot folder
4.) With the image still being displayed full screen in kodi, i press the info key on my remote to bring up the photos's info dialog on top of the fullscreen image.
5.) With this info dialog on screen i press "5" again, attempting to take another screenshot. Nothing happens. I press "5" once more. Still no screenshot is taken
Any idea how I can take a a screenshot of the photo info dialog?
Thanks so much for looking into this!
It's only picking it up as screenshot once HandleKey: five (0xf035) pressed, action is screenshot
, the other 2 times it's just the number 5 HandleKey: five (0xf035) pressed, action is Number5
. So you might need to add another map for the number 5 for the window pictureinfo
(2021-09-15, 19:00)Hitcher Wrote: [ -> ]It's only picking it up as screenshot once HandleKey: five (0xf035) pressed, action is screenshot
Thanks so much Hitcher. I use the keymap editor addon to assign the "5" keypress and i had thought that doing so under "global" and "picture slideshow" would have been sufficient. Thanks for alerting me to the fact that
pictureinfo
would need it's own mapping.
Only issue is that I don't think this is possible using the keymap editor addon? At least I couldn't find a way to do so. Do you know what xml edit would be necessary to achieve this?
Thanks again - very kind of you to help out
Got it working. Thanks again!
