Full Version: Formating menu text
I need some help with formating text.
In my old addon it was written like this:
AddDir("[COLOR yellow][b]{0}[/b][/COLOR]".format(getLocaleString(30001)), "newList" , 20, os.path.join(iconsDir, "NewList.ico"), isFolder=False)
The color is good but the problem is with the bold tags, it shows it like this:
How can I fix this? in Kodi 17.6 it was ok.
I found the problem, it was because the encoding issue in the getLocaleString function
def getLocaleString(id):
    return Addon.getLocalizedString(id).encode('utf-8')
After remove the .encode('utf-8'), it's ok now
