Full Version: Fanart api key
I have generated a personal fanart.tv api key, its worked on my fire TV but hasn't worked on my shield setup, can i use the same key on more than one device, or if i generate another key, will that delete my original key?
(2021-09-04, 12:33)Robertsond1987 Wrote: [ -> ]I have generated a personal fanart.tv api key, its worked on my fire TV but hasn't worked on my shield setup, can i use the same key on more than one device, or if i generate another key, will that delete my original key?
Yes, you can use the same API key on another device.
(2021-09-04, 12:58)shedrock Wrote: [ -> ]
Thanks. Not too sure why its not working on my other device then. Same skin, same addon.
