Full Version: reload keymap in kodi 19
This is not opcion anymore in kodi 19, does anyone have a solution for kodi 19, how to reload keymap.
<onfocus>XBMC.Action(reloadkeymaps)</onfocus>
Have you tried just not using the XBMC prefix?
https://forum.kodi.tv/showthread.php?tid...pid2934411
(2021-09-12, 22:45)Fuzzard Wrote: [ -> ]Have you tried just not using the XBMC prefix?
I did, but it doesn't work
(2021-09-12, 23:13)senna99 Wrote: [ -> ]
This works for me in my keyboard keymap (using windows 10). I think it works on my Shield, but aren't quite sure
<k mod="ctrl,shift">ReloadKeymaps</k>
(2021-09-12, 23:49)KidKiwi Wrote: [ -> ]
Thanks, I'll try.
(2021-09-12, 23:56)senna99 Wrote: [ -> ]
(2021-09-12, 23:13)senna99 Wrote: [ -> ]I did, but it doesn't work
Thanks, I'll try.
It's working for now, thanks.
<onfocus>Extract(special://skin/resources/keyboard/HomeMain/joystick.zip,special://home/userdata/keymaps/)</onfocus>
<onfocus>ReloadKeymaps</onfocus>
(2021-09-13, 00:11)senna99 Wrote: [ -> ]
(2021-09-12, 23:49)KidKiwi Wrote: [ -> ]This works for me in my keyboard keymap (using windows 10). I think it works on my Shield, but aren't quite sure
Thanks, I'll try.
Glad it works for you Smile
