Full Version: m-TVGuide
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
my kollege do some little modifications about notifications, also i do my own page up and down buttons, position of the clock....and many little things in the xmls...font and so on
@Kangool The file you uploaded don't contain any changes from skin.default, please check if you have sent me the correct file. I made a file diff comparsion between skin.default and skin.defaultmod and got that the files are identical.
ah ok i will look again
How do i set up Telia play Sweden with epg from https://www.honeybee.it/xmltv ? I cant get no channels / no epg match..
@Jönke I can't see any EPG content, seems to be blocked by a subscription. If you can provide me the channels id I could add support.
By default EPG should match for eg. SVT 1:
SVT 1
SVT 1 SE
Or you could add specific channel id to basemap_se.xml
@Jönke Should recognize the channel ids now, try restart the addon.
P.S
Telia Play catchup fix:
https://github.com/Mariusz89B/script.mtv...g/9.8.3_v1
Thx but same issue
I Will pm my log
@Jönke  Sry, I forgot to save the updates I made on our server. Try again and restart the addon.
Still no go..
Just to make sure , same .zip as above?
Hi, thanks for taking this on.
Is there a place where people can post their skins and shows the various screenshots of the different skins?
@xDetoursx You can post your skin here, if it meets the requirements and with your permission I will upload it on our server and make it official.
@M89SE  any chance that you could add support for https://github.com/add-ons/service.iptv..../issues/63
I would love to be able to use Telia play in Kodi pvr Smile
"IPTV Manager integrates your Kodi add-on live streams and VOD content in Kodi's TV/Radio sections and TV guide interface.
We are ready now to promote IPTV Manager support wider to the Kodi add-on community, because:
It is now part of the official Kodi add-ons
It is pretty well documented and standardized (JSON-EPG and JSON-STREAMS)
It is made easy to add support
It offers a nice user experience to users and works out-of-the-box
It enables add-ons to coexist when using PVR IPTV Simple
Add-ons that are applicable for IPTV Manager integration are add-ons that are typically providing access to broadcasted content. They fulfill one or both requirements:
Has live TV streams
Has EPG data and VOD content"
@Jönke Sorry to say, but this will not be supported.
hi @M89SE
sorry i had many work and now was holidays
here the standart skin with little modifications
is realy very little
skin.default1
i must look when i have time to make a good modded skin...
but know i working again on my stalker plugin...i can now get all vods and i get also all tokens...but i have a litte problem to get onlz the js from selected categorz and not always all
may you can take a look https://forum.kodi.tv/showthread.php?tid...pid3079453
