M89SE , question. Is there a way to add more than one link option for a channel? So when you click a channel it can give you more than one option to play it with? For example I have 2 addons that provide the channel. Like Ivue works where it gives you options to play choosing what addon you prefer. Maybe just an option choose a second channel link in the guide when using the context menu/Choose stream option? Just curious. Thanks.
jdig4240 There is no built-in method to add a second stream, but it is possible to modify the source.db file in userdata/script.mtvguide and add a identical channel name with different stream source or as for M3U playlists the add-on will recognize multiple streams so you could create a playlist and add it as a source in m-TVGuide settings.
eg. filename test.m3u
#EXTM3U
#EXTINF:-1 tvg-id="channelone.uk" tvg-name="CHANNEL 1 UK" tvg-logo="my_logo" group-title="UK",CHANNEL 1
https://your_stream
https://your_stream_2
https://github.com/Mariusz89B/script.mtv...st_enabled
(2022-01-26, 00:16)M89SE Wrote: [ -> ]@jdig4240 There is no built-in method to add a second stream, but it is possible to modify the source.db file in userdata/script.mtvguide and add a identical channel name with different stream source or as for M3U playlists the add-on will recognize multiple streams so you could create a playlist and add it as a source in m-TVGuide settings.
#EXTM3U
https://your_stream
Sweet, so in the source.db file, i would add another line in the custom_stream_url section of the .db file. Looks easy enough. So after i do this would the guide ask me to choose which stream to play I assume?
The guide sets them in order, you can then switch stream while playing using Context button.
Hi, newbie here
I installed the addon on Matrix 19.4 running on Linux Mint 19.3. I followed the installation guide and I use a valid epg link and m3u playlist. When I try to record I get the following error: "can't record due to not configured record application RTMPDUMP & FFMPEG".
I have both pvr iptv simple client and nextpvr running. During installation it said that ffmpeg was imported.
Thanks in advance for your help
(2022-04-03, 23:01)M89SE Wrote: [ -> ]@Gaulthier Hi, sorry for a late answer. In the m-TVGuide settings you need to install record apps and set a record location to start a recording.
https://github.com/Mariusz89B/script.mtv...record_app
No problem. I went to the settings page but the list is a lot shorter than the one shown in the wiki, and there is no "install record apps". I'm in expert mode of course. The destination folder I chose with the installation wizard, so I guess is set.
Gaulthier You need to use the scroll button, it's there trust me.
(2022-04-09, 21:31)M89SE Wrote: [ -> ]@Gaulthier You need to use the scroll button, it's there trust me.
Yeah sorry, I didn't see that the left menu was also a scroll down one. That being solved I now cannot find a m3u list with matching epg for italian channels. That is I have them and they work well with PVR IPTV Simple Client but not with m-TVGuide. I tried a couple with no luck. Any pointers? Thank you for your patience.
Is there a way to get this add-on working on a Nvidia Shield runnning Kodi 19.3 and tvheadend?
With my current setup free to air TV EPG shows in the built in TVGuide. I want to add some IPTV channels from addons to the guide too.
I have created an EPG of the IPTV channels (xml) which I have linked in the add-on under EPG. When I start the add-on I get a popup saying it is doing its thing - it then says it must restart which it does. I then go to the Live TV guide and it is still the stock kodi guide with no option to add channels/streams or anything. The m-TVGuide seemingly never loads and I cannot even get to the context menu on my nvidia shield to add the channels I have added to favourites. Relevant parts of the log:
https://paste.kodi.tv/oyakidivov.kodi
Am I doing something wrong or is this add-on not compatible with tvheadend front end running on nvidia shield? Skin is Arctic Zephyr Reloaded if that matters.
In the latest versions I no longer see the "Show only programs with streams assigned" or "Automatically assign streams" options anywhere in settings? If i cant disable these settings, i cannot load my EPG to assign channels without having a playlist file.
**Edit** So I went back versions of the guide and found that these options disappeared starting with 9.9.3. Above settings are present in 9.9.1 and below and now I can successfully load my EPG.
jdig4240 I have checked both on Kodi v18 and v19+ with the latest m-TVGuide release version 9.9.604 and the options "Show only programs with streams assigned" and "Automatically assign streams" are present on both versions.
(2022-05-04, 16:38)M89SE Wrote: [ -> ]@jdig4240 I have checked both on Kodi v18 and v19+ with the latest m-TVGuide release version 9.9.604 and the options "Show only programs with streams assigned" and "Automatically assign streams" are present on both versions.
Strange, installed it again and still dont see the options..
